Question about Health & Beauty
Road knight maxi scooter wiring diagram
No power from ignition switch nothing work
5 Suggested Answers
  • 177 Answers
SOURCE: road knight mini, 3 wheel scooter, light flashes o...
Hi. Does the light flash a few times and then pause, and then repeat the flashing ? Count the flashes, it is a fault code. Do you have the fast/slow switch in slow? It might be a speed control fault. How old are the batteries? Might have a faulty motor. Faulty motor or battery leads and connectors. Go for a ride and then check if any of the plugs and sockets feel hot.
Posted on May 28, 2010
  • 177 Answers
SOURCE: wiring diagram for sc234ala mobility scooter
Hi. Do you need a basic wiring diagramme for the lights, motors etc. or do you need one for the controller? What faults do you have?
Fisher and Paykel sold their mobility scooter business to Plega Healthcare in Australia. Plega now no longer suport the mobility scooters.
We have some parts left in stock, and were an authorised service agent for these machines.
No one was ever supplied with a circuit diagramme for the controllers.
We do have all the service manuals here and have a full set of the fault codes.
You can email us at scooterworks@xnet.co.nz
Good luck. Neil.
Posted on Jul 24, 2010
  • 347 Answers
SOURCE: the power lift on my
hi,can you rate me in 1 to 4 thumbs up.im disabled myself & do cause i care.if you visit:www.alldatasheet.com .type in your product details & download what you ask for in PDF File with Adobe Reader.Save it & or print it for future use.Colin.
Posted on Sep 09, 2010
gewiz
  • 1271 Answers
SOURCE: How do you lower the handlebars on a Road-Knight mini mobility scooter
is it possible to supply a picture of the scooter in question if its the one i think it is, has it got a tighting up collar on the front stem ?
Regards
Posted on Dec 09, 2012
I have a 2000 Saturn that won't start. NEVER had a problem before. Turned it off and it hasn't started since. No turnover, no click, nothing.
Could be your key ignition switch. It helps to complete the circuit... but do you hear a clicking when you the the key. If you just hear a clicking noise, It is your starter if you hear nothing it could possiblely be the ignition switch. My riding lawn mower did the same thing. It turned out taking a can of air and cleaning out the key hole worked but it sounds like the ignition switch could be bad.
Oct 27, 2017 | Saturn Cars & Trucks
I have no power at all when the key is in , no light in the dash nothing
Do you have headlights with the headlight switch on? That would eliminate a battery connection problem. If things like headlights and brake lights work, one should next check that power is getting to the ignition switch. If you pull the connector under the dash off for the ignition switch, there should be a hot-at-all-times wire going to the ignition switch. Check with a test light or voltmeter. If no power to the switch, back to the fuse box by the battery-an ignition fuse may have blown. If power is available to the switch, suspect a bad ignition switch.
Apr 10, 2014 | 2002 Pontiac Sunfire
Turn switch on and dash has power but nothing else
More than likely it is the ignition switch or wiring to it. If brake light or horn is working then check red/black wire from ignition switch for 12 volts. This wire feeds the headlight and ignition circuit.
Mar 28, 2014 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Wife goes to start our 1991 Dodge Shadow and nothing. headlights work, dome lights etc. but anything that is tied to the ignition won't work. So I have been trying to find out where the ignition switc
It is on the steering column, below the ignition lock cylinder.
Before changing the switch, pull the electrical connector apart for the switch, and check for a power signal into the switch.
Probably a fusible link off the battery supplies power to the switch. Check that you have one hot wire going to the switch-one wire should have power available on it at all times. If no power to switch, check fusible links. If there is power available, then go ahead and replace the switch.
Nov 26, 2013 | Cars & Trucks
I have a 88 bronco 2 Everything was fine until yesterday it had no power what so ever I took two fuses out of it because they went bad but I replaced them I have no power in my dash board or nothing but I...
See if the ignition coil has power to it with key on. Does anything work with key on? Like the warning lights and gauges? Radio and wipers? If the ignition switch is not getting power to it and sending it out, with key in on, accessory, or start-then nothing will work, no starter, no ignition, no accessories.
Recheck all the fuses. Check if you have power to the switch-probably a fusible link off the battery is the supplier of power to the switch, although it might be a maxi fuse.. A voltmeter or test light will be of great help to you in checking for power.
Sep 11, 2013 | Cars & Trucks
Turn the key and nothing
Check battery cable connections. There should be a hot wire (hot at all times) to the ignition switch, and when key is turned the switch sends power out. Either the switch has lost the power in, or the switch is bad, not sending power out.
Do the headlights work? When key is turned to on, do the warning lights and gauges come on in the dash? Does the radio or any accessories work when key is turned? If nothing works, you need to check if the ignition switch is getting power from the battery.
Aug 13, 2013 | Cars & Trucks
92 plymouth voyager wont start and nothing work the windows wont go down the lock and unlock button does nothing idk what the problem is i had the battery tested and the battery is fine what would cause...
Nothing works? How about the headlights, do they work? If yes, then start checking all fuses in the Power Distribution Center or Box under the hood. If no, then look for a bad maxi-fuse in the PDC, and check for a bad fusible link between the battery and the PDC. The battery positive cable goes to the starter, but a pigtail lead off the positive would go to the PDC, to distribute power to all the various circuits on the car.
When you turn the key to on, does the dash light up? If yes, at least power is getting to, and going through the ignition switch. One could then check for power on the starter solenoid wire when key was held in crank or start position.
If nothing when turning key to on-no dash lights, nothing-then check for an ignition fuse in the PDC. If fuse is good check for power being available at the ignition switch connector. If no power there, check wiring between PDC and the ignition switch-if power is up to the switch, but nothing happens with key on, no dash or warning lights, then could have a bad ignition switch.
It just sounds like a maxi-fuse has blown, or a bad fusible link. Good luck.
Mar 18, 2013 | Cars & Trucks
I have a kawasaki Z1100. This morning when I put the key in the ignition nothing happened. No lights,No power, Nothing any ideas what I should be looking for?
it is surely on the ignition switch might not working or stucked up the connectors inside it...,unless no one sabotaged your motorcycle that he cut the battery terminal & ignition terminal of your motorcycle.Check the wirings at the very bottom of your ignition switch if there are cuttings.
Nov 04, 2009 | kawasaki Z 1000 Motorcycles
Lost power
Does the starter works? If it will not, maybe your problem is in the ignition switch.
May 22, 2009 | 1994 Suzuki Sidekick
Health & Beauty Logo
76 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
