Question about Xerox Phaser 8560DN Laser Printer
Xerox phaser 3636 mfp prints blank first page
  • 2072 Answers
SOURCE: Xerox Phaser 8560 mfp Printing issue
That really sounds like you need to replace the maintenance kit.
The white roller most likely is black and has depleted itself of lubricant a bit prematurely.
Posted on May 21, 2008
ikechinedu
  • 184 Answers
SOURCE: Invalid Black Toner Xerox Phaser 6110 MFP
reload the driver again and if it persists, change the toner
Posted on Jun 23, 2009
  • 2072 Answers
SOURCE: printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Posted on Mar 10, 2010
wrinaldo
  • 185 Answers
SOURCE: xerox phaser 8560 1st page is blurry. The 2nd page is OK.
The good news is that you don't need any parts.
The oil from the drum is drooling to the right side to the Drum Position Sensor is located.
Remove the right cover. Remove the fan. Loosen the clear plastic cover under that. Clean the sensor and all the wires with very pure Isopropyl or denatured alcohol.
The situation may reoccur every year or so.
Whit
Item, Inc.
Posted on Aug 10, 2010
SOURCE: Xerox Phaser 6180 MFP-D password
The default password is "00000" If this password does not work you can follow the following to reset it:
  1. Power OFF the machine using the power switch located on the right side of the machine, toward the back. Press the power switch to the (O) position.
  2. Press and hold the [OK] button on the Control Panel.
  3. Continue to hold the [OK] button and power ON the machine. Keep the [OK] button held down until the Ready screen is displayed. The password is now reset to the default Control Panel password, which is 00000.
    NOTE: There will be no confirmation message during or after the machine's power on sequence. However, if the procedure was performed correctly, the password has been reset.
Posted on May 29, 2011
I have just bought a Xerox Phaser 6500. Prior to this I had a phaser 6125. The problem im having happened with both printers which makes me think somewhere along the line my settings are wrong. If I...
You may have the "separator page" option turned on in your print driver. This option will insert a blank page after each print job to separate one print job from another. Simply uncheck the box by the separator page option and you should be back to normal !
Oct 21, 2013 | Xerox Phaser Office Equipment & Supplies
I have a Xerox Phaser 3300 MFP wITH BLANK COPY i CHANGE MAINCONTROLLER, LASER UNIT pOWER SUPLYANY iDEA
If you can print any internal report from the machine or from your computer then the problem is in your scanner.
If you cannot perform any print function then probably the laser assembly has failed.
Mar 14, 2012 | Office Equipment & Supplies
Hi, I have xerox phaser 3100 mfp , when I try to copy or scan, only I got a black paper and not clear at all,,,, but when I try to print from the computer, it's OK... so what is the solution,...
The problem is with the hardware of the printer and all you can try is to reset the scan settings on the scanner .. clean the scan bed.
If neither of them works then it might be time to buy a new one.
Oct 25, 2010 | Xerox Phaser 3100MFP/S Laser Printer
I have a Xerox Phaser 6180MFP and when I print #10 standard envelopes and #9 renturn envelopes the envelopes come out with badly pressed wrinkles on the end of the envelope that comes out last. I have...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
May 21, 2010 | Xerox Phaser 6180N Laser Printer
Jun 23, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Xerox 3500 blank pages xerox 3450 display flashes
Clear all memory under maintenance will solve this
Feb 05, 2009 | Xerox Phaser 3450DN Laser Printer
May 21, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser  8560DN Laser Printer Logo
123 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
