Y CRUM Error Error 093-950 restart printer
Lexmark X560n Laser Printer. Came in the office this morning to this problem & cannot fix. Have restarted numerous times. No luck same error continues. Please help.
    New Friend:
  • 30 Answers
If new, did you remove the safety paper?
Posted on Nov 26, 2013
  • Ange Kenos
    Ange Kenos Aug 23, 2015
    my Yellop is not even half way - are you sure a new cartridge is required please?
  • 13433 Answers
SOURCE: Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Posted on Jun 26, 2008
IrishDruid
  • 2712 Answers
SOURCE: Lexmark X6570 printer - Cleared
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Posted on Nov 11, 2008
SOURCE: Printer Error-->
I just moved to Alaska and shipped this printer up and had the same problem. What I found was that when I start up the printer, the carrier that holds the printer cartridges would not move all the way to right side of the tray. You can see this if you open up the top portion of the scanner glass carrier.
Turn off the power and remove the electrical plug from the back of the printer to be sure no power is feeding the printer.
If you closed the top of the printer, the part where the scanner / copier glass is at, open it back up.
Reach into the printer and manually move the piece of plastic that holds the print cartridges to the left.
Directly underneath where the print cartridge carrier defaults to on the right hand side of the printer you will see a piece of white plastic on the bottom. It will probably be sticking up. It is hinged. Push it down gently so that it rests down inside of the indention where it is supposed to be.
Plug your printer back in and turn it on. The printer will go through its self test, and if this was the problem will work correctly for you.
Spencer
Posted on Dec 07, 2008
leroyal
  • 2120 Answers
SOURCE: Error #006-370 Restart Printer
call a Lexmark printer repair company
Posted on Jan 28, 2009
copiersplusw
  • 136 Answers
SOURCE: error 010-397 restart printer
I would Hold down the "Menu" and "Cancel" Button then for "Reset Printer" ,Turn Off the Printer remove the cartridges then reset them again. Along with the Drum Unit. Something is Not Seating properly
start thier first.
If I could be of further help or your in the CT area then contact us:
http://www.copierspluswwllc.com
Posted on Oct 10, 2009
Y - CRUM Error / Error 093-950 Restart Printer
093-950 Y - CRUM Error
Error 093-950
Restart Printer
The yellow toner Smart Chip error is detected
Error with detecting or defective yellow toner cartridge. Replacing cartridge should correct it.
Paul
Nov 25, 2013 | Lexmark X560n Laser Printer
Error code 017-988
In Windows, reconnect the USB connection between the PC and the printer, and enable Windows Image Acquisition (WAI):
1. In the Control Panel, select Administrative Tools.
2. Select Services.
3. Select Windows Image Acquisition (WIA).
Dec 14, 2012 | Lexmark X560n Laser Printer
No desplay on the screen and not able to print. and it saying on the Addres book Fatal error. How can i solve this problem
Hi abianota,
Have you tried restarting the Machine? turn off the power then unplug the power cable for a few minutes.
Mar 20, 2011 | Lexmark X560n Laser Printer
We have an error message CRUM 009-367 and we are unable to figure out what is wrong with it on our Dell 3110cn. Thanks
009-367:The Yellow (Y) Toner Cartridge CRUM Data error is detected.
  1. Cycle power on the Printer.
    1. Turn the printer off.
    2. Wait 10 seconds.
    3. Turn the printer on.
    4. Determine if the issue still occurs.
  2. Verify that the toner installed is Dell toner
  1. Cycle power on the printer again.
  2. If the error persists, replace the desired toner cartridge.
    • If the desired toner cartridge has already been replaced, replace the Toner Dispenser CRUM.
    • If the Toner Dispenser CRUM has already been replaced, replace the Printer.
Mar 07, 2011 | Dell 3110cn Laser Printer
Scanner will not work error code 117-363
error code 117-363.make sure there are no loose power cables/leads that are attached / data cords etc..
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Jan 27, 2011 | Lexmark X560n Laser Printer
I have a lexmark x560n printer. It will print from computer perfectly but when I scan or copy something the right side of the copy has the ghost image while the left5 side is perfect? Whats up with this?
Something is blocking the scan light. Dirty glass or something like that. Check the scanner glass and the scanner lid.
Please rate, and write testimonial if you feel the need to, if this was helpful.
Good Luck
cookieMonster
Oct 07, 2010 | Lexmark X560n Laser Printer
I LOST MY INSTALLING CD FOR LEXMARK X560N.I WANT TO REINSTALL THE PRINTER
Here's the link for the available Lexmark X560N drivers: http://bit.ly/cQd6Zo. Click on the Microsoft, Macintosh or Linux/Unix drop-down found below the page to choose the version of your computer's operating system. Download and execute the file. Thanks.
Aug 20, 2010 | Lexmark X560n Laser Printer
Error message 241.10 but there is no paper jam. Is there a way to override or fix this error message?
This is what I think is the solution. Uninstall your printer driver and then restart your computer. Then install it again.
Apr 03, 2010 | Lexmark T640 Laser Printer
900 service RIP software error on boot-up
removed memory off the system board restarted printer. came up to an error no memory found.
powered down and reinstalled memory on board in a different slot and restarted unit...
NO ERRORS......
May 24, 2009 | Lexmark C750n Laser Printer
192 people viewed this question
k24674
jasbo
jasbo
