Question about Minolta PageWorks 20 Laser Printer
Won't print ledger size
I can't print to the ledger size paper.  When sent to the laser, it pops up with "load ledger" and flashes the yellow error light.  The ledger paper is of course loaded but the machine is not recognizing it.  I went as far as buying a second pageworks 20 on ebay, but it has the same problem.
I had my first machine for years and years and never had a problem till recently.  Printing to this size is the reason I purchased these printers so I need to get this working.
I've done my best to clean everywhere I could and have just run out of ideas.  Help!
  • jandt711 Jan 27, 2008
    i use the pageworks 20 for autocad on 11 x 17, w/ the same problem it worked for about two years then stopped printing 11 x 17, says to load ledger paper already in the manual feed tray i push proceed and it prints 81/2 x 11 fron the tray when the 81/2 x 11 tray is empty it'll print from the manual feed tray but wont feed the entire 11 x 17, itll stop half way thru
  • Minolta Master
  • 6,825 Answers
Are you loading the ledger in the right place main tray or by pass?
Printer properties set correctly?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 26, 2015
kevin000
  • 1847 Answers
SOURCE: Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Posted on Sep 09, 2008
SOURCE: error code c0500
You probably have a bad fuser.
Posted on Oct 10, 2008
  • 5 Answers
SOURCE: REPLACING CARTRIDGE
You should be able to replace just the needed color.  Select menu, arrow right until "Engine" is displayed, select, select "Replace Toner" select color cartridge desired. follow directions on screen.
Posted on Mar 25, 2009
  • 9 Answers
SOURCE: QMS Minolta 2400W doesn't print
try lifting the drum assembly, at the back of the assembly there is a fuse. replace it. hope this helps
Posted on May 25, 2009
  • 9 Answers
SOURCE: won't print or pick up a sheet of paper
toner cartridges of the 2400 laser comes with a counter chip. if it reaches its limit or the number of pages it should print. the toner cartridges are unusable anymore. try buying new cartridges or if you could find a supplier of the counter chip it would do just fine.
Posted on Jun 10, 2009
When I go to print I get message load mpf 024-969
This error typically means that the Size of paper defined in the print job being sent from the application does not match the size of the paper the printer has set for the MPF. (in this printer, MPF = Manual Feed)
For example: If you send a Letter size job to the printer from, lets say MS-Word, but the printer currently has Legal size paper assigned in the MPF, this error will result.
Change the Windows printer to default settings
Apr 03, 2014 | Dell 3010cn Laser Printer
Whenever a print job is sent to my dell 3100cn laser printer, ?Load tray 1? appears in the small window of the printer. I loaded the tray several times but it doesn?t work. Please guide me through the...
You sent a paper size different of the requested by the printer. Just load the requested size or delete the spool.
Some PDF downloaded from internet has A4 or 8,5x11", maybe is requesting one of this sizes.
If you can not delete this message, delete the spool using the printer manual in the control panel of the printer.
Dec 11, 2010 | Dell 3100cn Laser Printer
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Error messages and printing problems
Paper mismatch errors occur because the printer scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper size error'.
Try to adjust the printer and envolopee settings..
Regards,
polysandy
Apr 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
False Jam at exit on a Toshiba DP3580 copier
make sure your drawer size shows 11x17 on display if not push user interface button then select the drawer and set it to 11x17
Jul 04, 2017 | Toshiba DP2570 Printer
Load mp feeder error optra t 642 printer
I received this message when I was trying to print a pdf file. I attempted messing with the positioning of green paper guide to no avail. My co-worker suggested I uncheck the Choose paper source by PDF page size box on the Print pop-up box. This did the trick.
Dec 08, 2009 | Lexmark T642 Laser Printer
Paper light flashing popping noise
The problem sounds like the rear paper guide of the paper tray is too tight aginst the paper. Back the guide off about 1/16 of an inch and see if that helps. You may also want to check and make sure the tray is set for the correct paper size of the paper you are using. Good luck!
Oct 09, 2009 | Brother HL-5240 Laser Printer
CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Dec 01, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
Minolta PageWorks 20 Laser Printer Logo
150 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Inky Fingers
Inky Fingers
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
