Question about Samsung Computers & Internet
Hard drive issue
Hi sir, when i start the computer i find some breaking sound is coming from my hard drive,my monitor displays windows did not find any hard drive.
    Genius:
  • 1,198 Answers
Oh, it found it, it's just broken. Hope you saved a backup file elsewhere.
Posted on Nov 26, 2013
3 Suggested Answers
SOURCE: Lacie 750 GB External hard drive
Dear,
Please check your BIOS setting. Make sure that Boot from USB device/drive is disable.
Reply....
Regards,
Rakesh Kumar
Posted on Apr 01, 2009
  • 109 Answers
SOURCE: my hard drive is not displayed in my computer and
Sounds like a hard disk failure. You may need to take it to a samsung repair center to retrieve any data or replace on warrenty.
Posted on Sep 11, 2010
I have a Asus Rampage Formula board w/ 4gig mem, was running a BFG GTX 260 max core nvida card , win XP pro 32 bit sp4. I have had no issues for about 1yr then when the computer would run for a few hrs the...
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | ASUS MB RAMPAGE FORMULA 775 X48 RT...
No display on screen but lights on keyboard. The battery and power lights come on and the hard disk light blinks, but there is no display on the screen
Try an external monitor on the laptops vga output, if the external monitor works ok then you have either a faulty screen or inverter
Apr 05, 2010 | Toshiba Satellite A135-S4527 Notebook
Signal has gone
If the monitor comes on and displays a message like "no input signal" or something similar, it's working properly but there is nothing coming from the computer. People often think that the computer is working and the monitor is at fault, when in fact the computer isn't starting up.
When you turn on the computer, do you hear the normal sounds of the power supply fan running and the hard drive spinning? Most computers will give a beep when they turn on and the motherboard finishes some startup checks. Do you hear that? Do you ever hear the normal startup sounds that mean Windows is actually running?
If you are convinced the computer is starting and booting into Windows, I would suggest you borrow a known good monitor to use as a test. If it works, that obviously means yours is bad. In most cases there's nothing you can do to repair a monitor yourself beyond checking for loose connections, bent pins in the signal cable plug, or a damaged cable.
If a known good monitor still has no image, the computer is at fault. Either the video card or integrated video isn't working, or the computer isn't actually starting up. In any case, that's where you would need to start looking for the cause.
Hope this helps you along the way to solving the problem. Thanks fo using Fixya!
Feb 02, 2010 | ViewSonic VX2235WM Monitor
SIR, PLEASE GIV ME THE BEST SOLUTION FOR FOLLOWING PROBLEM WITH MY LENOVO 3000 Y410 LAPTOP (WITH XP AS O.S. ) ON MY EMAIL_ID=swatijadhav44@gmail.com AS EARLY AS POSSIBLE. SIR, MY LAPTOP SCREEN STAYS BLACK...
You can't even get into the BIOS. Hard drive failure?
Here's what the manual say's about black screen.
Verify that: The monitor cable is securely attached to the rear of the monitor and to the rear of the computer.
The monitor power cord is plugged into the monitor and into a working electrical outlet.
The monitor is turned on and the brightness and contrast controls are set correctly.
The voltage is set to the correct setting for your country.
The monitor signal cable is securely connected to the monitor and to the monitor connector on the computer
.Note: If your computer has two monitor connectors, verify that your monitor is connected to the one in the AGP option connector rather than the one in the rear of the system board.
If you can check the monitor by using another monitor.
I suspect hard drive failure. Keep me informed on what you tried and I'll keep checking to come up with solution.
Sep 23, 2009 | Lenovo 3000 Y410 Laptop
Princeton Monitor is "out of range"
The monitor is not getting a video signal. This is probably an issue with your computer. It could be a memory, hard drive or motherboard issue.
Make sure you are getting power to the pc (fans running, hard drive spinning...etc). Then check your memory. Try switching memory slots, or try different memory.
Turn on computer and see if you hear any bios beeps.
Try a different hard drive if you have one.
Good luck,
Hank
Aug 04, 2009 | Princeton Digital VL1916 19" LCD Monitor
No display on computer
First thing is do you have a beep when the system boots? Sounds like you may have a BIOS issue I would start there........your RAM and processor are more than likely NOT the problem
Apr 15, 2009 | HP Pavillion a818n Desktop PC (Refurb)...
Windows Vista does not come on the screen when I turn on my computer.
Try removing the battery and using the laptop only with wall power.
May 19, 2008 | Computers & Internet
Monitor settings
Have you checked the actual board that has the buttons to see fi there is an issue there?
If you've found nothing there and still experience the issue, sounds to me like you might be looking at a bad micro.
Nov 21, 2007 | HP Compaq FS 7550 17" CRT Monitor
X5DAL-G restart
if theres a click, then its either the hard drive or the monitor click when it shuts off, motherboards don't make a sound. When its starting up press F8 to enter safe mode and select last known good configuration and see if it starts as normal, but is sounds as though the boot.ini is damaged on a bad sector of the hard drive and either try a windows repair or replace the hard drive.
Sep 26, 2007 | GE Supermicro X5DAL-G E7505 Mainboard...
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
