Question about Zebra Eltron Office Equipment & Supplies
ZB EPL2 command
I am creating a custom label with Eltron language code and would like to know whether the ZB command overrides the entire orientation even if used at the end of the label? In other words, if the template I use (which I cannot alter) uses a ZT command at the top of the label to turn the entire label upside-down, will using a ZB command at the end re-orient the entire label to right-side-up?
5 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Okidata - label printing alignment
You might try setting up Word for a 'custom' label since it offers that option.
I've done some strange labels by directing Word via that feature.
Posted on Aug 26, 2008
  • 6 Answers
SOURCE: Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Posted on Sep 25, 2008
  • 7 Answers
SOURCE: print orientation
If you are printing from the included software, it has options for labels with vertical printing. If printing from a third party program, you can go to the dirver settings and change the printing orientation.
Posted on Dec 31, 2008
  • 62 Answers
SOURCE: TLP-2844-Z only prints using EPL2 not ZPL2
Download firmware, get latest firmware & Firmware download utility software directly from the Zebra website
Posted on Dec 04, 2009
Print dosent stop
u have to create your label at printer properties.
if prints doesn't fix your label, this problem appears.
( for 80x40 cm barcode: open printer properties-printing defaults - label size - new custom size or new label - write your sizes at size fileds- and save)
open your app, and create new file, type your sizes for new file, and print it!
Jun 25, 2013 | Zebra Eltron TLP 2844 Thermal Label...
I am trying to install a lp 2824 plus zebra label printer and i need to know whether to select epl or zpl?
You should probably select ZPL, but that depends on which program you will use together with the printer.
Jun 20, 2011 | Zebra LP 2824 Printer
What is the difference between the Zebra LP 2844 Thermal Printer and the Zebra LP2844Z?
lp2844 use programming languages EPL2, Line Mode, lp2844 use ZPL II, ZPL (Zebra languages), both are Direct Thermal (don't use ribbon), not Thermal-Tranfer (use ribbon).
Nov 17, 2010 | Zebra LP 2844 Thermal Label Printer
Currently have a TLP2742 duplicator which prints barcode and text. Need to alter this to just print the text. how do i do it?
Do you know if you are using a label software program to design the label or just ZPL (which is Zebra Programming Language) code direct to the printer? If it is software, then you can open that label design software file and remove the barcode. If it is ZPL, then you need to remove it from the code. I can help with this if you can email me the code.
hilster1968@gmail.com
Jun 26, 2009 | Zebra Eltron TLP 2742 Thermal Label...
How Send EPL2 commands to USB
Use the Zebra ZUD driver. Latest version V5.5.7.25 (Download from Zebra website). When driver is installed, go to printer & Faxes folder and double-click on the installed printer icon.
Click Printer/properties/printer/advanced (+)/tools (Click on tools) This opens a text box. Type commands in here and send directly to printer. E.G type U click send and it will print a config sheet.
This definately works.
May 14, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844, Code Page for Arabic Character Problem
Download a free "Arabic" true type font. Use Zebra Designer to print your label and use the arabic font to print any character.
Apr 16, 2009 | Zebra TLP 2844 Label Printer
Zebra label alignment
you can adjust this in the template file for your price tags. how did you create your basic price tag label? in the zebra label creator? if so, make the adjustment there. if you have a .ejf file for your price tag label, you should be able to open it in notepad and add the height in pixel dots with the "q" or "Q" command from the EPL programming handbook. This can be a little tricky, but with some trial and error, you can get it.
EPL2 programming guide:
http://www.zebra.com/id/zebra/na/en/documentlibrary/manuals/en/epl2_manual__en_.DownloadFile.File.tmp/14245L-001rA_EPL_PG.pdf?dvar1=Manual&dvar2=EPL2%20Programmers%20Manual%20(en)&dvar3=2746e
Mar 23, 2009 | Zebra 2746e Thermal Printer
Eltron 2844 CTP Printer on Ubuntu
I got it working by selecting the Zebra manufacturer, EPL2 driver.
Mar 12, 2009 | Zebra LP 2844 Thermal Printer
Jan 12, 2009 | Zebra TLP 2844-Z Thermal Label Printer
PLEASE HELP - Labels are printing in the wrong direction
The ups site ahs a solution to your problem. You need to send a ZT command to the printer to reverse direction
The easiest way to do it is to open the printers properties and go to the advanced tab go to Printing Defaults then select Tools then tools again and a window will popup. Enter ZT and press enter. The Send button should now be enabled. Click on it. DO NOT touch anything else. Close all windows and try printing . If this is not the direction you want , rod and this time enter the ZB then enter. There are only 2 commands ZT and ZB
Good luck
Aug 22, 2008 | Zebra Eltron LP 2824 Thermal Printer
19 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
