Sony cechya-0080 When attempting to charge via usb, I get red light on mic for two seconds then nothing. Could it be defective battery? How do I replace it without damaging the unit?
bob_computer
  • 3153 Answers
SOURCE: Garmin C530 won't power up. I fully discharged
How old is it and does it get quite a bit of use
If so then consider replaceing the battery
Ebay has a good selection from a wide range of reputablesellers and very good prices
Check Here
Posted on Aug 26, 2009
  • 10 Answers
SOURCE: Sony KDL-46s2010 4 red light blinks
I would suspect one or more of the miniature flourescent backlight lamps. One way to confirm this would be to power up the set with a grayscale image at 40 to 60 IRE. If one or more lamps is failing to light, a slightly darker horizontal area in the grayscale will give it away. Unfortunately, Sony will not supply any of the backlight components apart from a new LCD panel. Sorry.
Posted on Sep 01, 2009
  • 18 Answers
SOURCE: headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Posted on Sep 04, 2009
  • 68 Answers
SOURCE: sony trinton 27inch red light blinks 11 times
those LED flashhing codeds are useless. You most likely have a problem in the high voltage circuits. You should bring that one to a local shop as it's very nlikely you can fix it yourself, and the high voltage circuits are dangerous.
Posted on Nov 06, 2009
nightlisa
  • 102 Answers
SOURCE: my usb port is damaged on my blackberry can not
The only thing you can do is use another BB to charge up the battery, and then swap batteries. Someone usually has a broken BB (screen dark, sound stopped working etc) which they will give you for free..
Posted on Jan 07, 2010
My new Dyson Serial Number PM8-US-HHB1494A will not charge.
Suspect a dead battery or a defective charger
Dec 28, 2016 | Dyson Vacuums
What is ritmo usb phone? A friend gave to me, said its for free international calls via internet. Looks like toy phone with usb cable, red lights flash when plugged into pc but nothing happens...?
You are hear to clarify your doubts. Ritmo USB is a Voip phone with Skype support. You can make and receive calls from Skype calls. Kindly plug into your computer's USB port inorder to make Skype calls from Ritmo USB phone.
Jul 13, 2015 | VIA Computers & Internet
Cechya-0081
Hello there,
I lost my CECHYA-0081 wireless adaptor driver for windows XP, anyone could kindly send me a copy or link to me at Frank_qiao@hotmail.com? With lots of thanks!
Mar 25, 2014 | Sony UWABR100 Network adapter USB ...
Battery charger flashing red
Although the manuals nothing says about flashing red light on charger, my best guess is the battery is defect.
Try to remove the battery several times and start the charging again and again. But when after a few attempts the LED starts flashing again, you better buy a new battery. When you don't use the camera for a longer period, make it a habit, to charge the battery every 3 months or so.
Jan 13, 2014 | Olympus Stylus 850SW Digital Camera
Plantronics audio 995H wireless headset not charging when plugged into computer. It does not show a red light for charging. When turned on it stays blue for several seconds then flickers red for 2 or
38cafd7a-6060-4717-bc4f-b4db91cc266a.jpgI recently fixed my 955 headphones... it's probably not going to be attempted by most folks, but it saved a great set of headphones from being tossed and replaced.
Basically you need to remove the right side padding and take out the 3 screws. This gets you access to the battery. The battery is a standard 3.6V lithium battery. Pretty much the same that is in most cell phones and many small toys. You can simply replace the battery with something like:
http://dx.com/s/3.7v+li
Or... here's what I did... add a lithium USB charger to the battery.
http://dx.com/s/li+arduino
Now, if the battery dies I can plug it into USB and the phone will work while it charges.
Nov 12, 2013 | Plantronics .Audio 995 Digital Wireless...
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
It is stuck on low battery screen and charging light won't come on.
Hi imrydn!
You can try these steps:
1. Connect the reader to the AC Adapter (If available). If not, then connect the Reader via USB to the computer
2. Hit the reset button for 3 seconds at the bottom
3. The red steady light should come on, if not, try the reset again while the unit is connected
4. Allow the reader to charge for 40 Minutes (on PC make sure the computer does not go into sleep mode.
5. Disconnect the reader and see if operational.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Aug 01, 2011 | Sony Reader Touch PRS-600
Have a motorola v3X Suddenly not charging
Just replaced a new cable or a new charger so you sure where is the defected even if battery defected it will charge but the battery it will not last long.If you replaced already new cable but problem still exist then the problem is the cellphone hub is crack or cold solder,you need to rebuild or resoldered it so it will works normally.
Got to cellphone to perform the soldering.
Hope it may help you;
Regards;
VOTIT
Jan 14, 2009 | Nokia 3650
Sony Ericsson K770i Phone won't turn on red light apears on the top left, any suggestions?
This has happened to me twice - the first instance occurred when I'd only had the phone a few days and the second occurred today after months of trouble-free use.
On both occasions the phone wouldn't charge via the mains charger - it wouldn't switch on even when plugged in and neither the battery or the charger were warm to the touch after hours of charging, indicating that nothing was happening.
The solution for me was to connect the phone to my PC via the USB cable - nothing happened at first, the PC didn't recognise the phone and it remained lifeless. However, I left it attached to my PC and after 10-15 minutes it suddenly whirred into life.
The battery was COMPLETELY flat despite my attempts at mains charging, so I let it charge via USB for a while then transferred it to the mains charger. This time the mains charger worked.
I've no idea why, but this has worked for me twice so give it a try.
Jun 07, 2008 | Cell Phones
383 people viewed this question
 Grubhead
Grubhead
