Question about Saeco Royal Professional Espresso Machine
Brew Unit Blocked
The Brew Unit Blocked error on our machine, how do we resolve this
    Habit-Forming:
  • Saeco Expert
  • 151 Answers
Open the door and see small screw in the middle of the brew unit. Take it off with small screwdrive and pull out the brew unit.Then put the small thing (something like a pipe) to the brew unit with the small screw. Then without brew unit in the machine press the switch inside the machine where stayin the brew unit and the switch witch is stayin the top of door .Switch on the machine and wait while self test is making,then put the brew unit in the machine and that it.Enjoy!
If you have any question -ask me.
Posted on Nov 29, 2013
5 Suggested Answers
SOURCE:
EsWorld
  • 1618 Answers
SOURCE: Gaggia Titanium Brew Unit Blocked
Check the shower screen on the brew unit.
Posted on Aug 06, 2009
espressodoc
  • 29 Answers
SOURCE: Brew Unit Blocked
If when you first turn it on and it does not go through the self test and then says brew unit blocked. You may have a wire loose on the board, (common) The motor that drives the unit may be bad. In either case you should have a professional look at it. Google saeco repair and have choose an authorized saeco repar center.
Posted on Sep 04, 2007
JohnnyBeans
  • 223 Answers
SOURCE: brew unit blocked
You can remove the brew group by following the "how to remove a jammed brew group?" on this page http://cerinicoffee.com/Saeco_technical_documents.asp
For Cleaning Supplies and Saeco Parts visit:
www.cerinicoffee.com
Posted on Jun 16, 2008
SOURCE: Saeco magic comfort has message brew unit blocked!
Manual on http://www.partsguru.com/user/Saeco%20%20Manual%20MagicComfortPlus.pdf
Posted on Apr 09, 2010
Brew unit blocked message The brew unit removed and switches jumped, motor turns message still blocked brew unit . what could it be and ways to tests.
I had the same issue. Very difficult to fix. You must remove brew unit and reset the machine while apart. You must trick the machine to think brew unit is installed and door closed. Look at door and brew unit and use screwdriver or butter knife to engage machine and run through cycle to reset.
Jul 09, 2011 | Starbucks Saeco Italia Digital Barista...
The machine is showing the brew unit is blocked but we have taken it out and cleaned it but this makes no difference.
Does the brew unit try to move at all? You can listen for the motor, or open the door panel and defeat the safety interlock while it's operating. (Be careful not to put a finger in there.) Then you can observe where the brew unit is getting stuck.
May 19, 2010 | Gaggia Syncrony Compact Digital Espresso...
Feb 01, 2010 | Saeco Magic Comfort 103467 Espresso...
My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
Jan 03, 2010 | Gaggia Titanium Espresso Machine
Aug 04, 2009 | Saeco Incanto Classic Espresso Machine
Brew unit blocked
May 30, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
The brew unit cannot be removed
I had the same problem. I apparently turned it off mid-cycle. The upper-left portion of the brew group stopped higher than it should have. I had to force the brew group out, breaking a small plastic cover in the process. I don't think that part's too important. Then I observed the orientation of the gears and visualized what orientation they needed to be in to re-install the brew group. I pressed all the sensors to trick the machine into thinking the brew group was installed and started the brew process. I released the sensors once the gears were in the necessary orientation. I re-installed the brew group and was back in buisiness.
Feb 17, 2008 | Saeco Incanto Classic Espresso Machine
Brew Unit Blocked
Sep 03, 2007 | Saeco 762111651808 Espresso Machine
Saeco Royal Professional Espresso Machine Logo
1,854 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
