Question about Tefal Irons
Tefal Pressing Plus 45 stopped working
Suddenly stopped working
The steam generator stops producing steam.
Sounds like it's overheating. May have an issue with the cooling system. Make sure the coolant system is functioning properly
Jun 12, 2016 | Tefal Irons
Continuous steam and green light flashing on my tefal steam generator iron.
I found this on a site and it works!! Put 50/50 mix of water and viniger in your iron, let it run, after a while start pressing the steam button, you may have to do this a few times, but it will eventually stop the light flashing, then the steam function will return to normal. You'll need to clean the iron out a few times afterwards
Jun 22, 2010 | Tefal Pro Express GV 8120 Iron
I have a tefal pressing steam station and im just wandering if you can get the water dispenser at the front off as it has alll gone green
Try to get some iron cleaning chemicals i.e. Wallmart sell it.
Try a little algiside that you add to the pool water to stop algie forming.
REMEMBER WHAT EVER YOU USE, FLUSH THE IRON OUT AFTERWARDS.
Aug 06, 2009 | Tefal UltraGlide FV4269 Iron
Tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Apr 22, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal program 8 500 Iron
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Mar 16, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal Pro Express - Constant Steam
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Jan 04, 2009 | Tefal Ultraglide 1549 Iron
Tefal turbo ro 400 iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Oct 08, 2007 | Tefal Ultraglide 1549 Iron
Irons Logo
24 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
