Question about Lenovo ThinkCentre® A51 PC Desktop
Thinkcentre m72e does not power up - Lenovo ThinkCentre® A51 PC Desktop
How do i reset it my wireless adapter
If I were you, I'd first let Windows Manage Wireless Network Connections:
  1. Click Start If you're using XP, click Start then open the Control Panel. Find the Switch to Classic View button in the Control Panel and click it.
  2. Open Network Connections Open Network Connections then double-click the Wireless Network Connection icon.
  3. Click the Properties Click the Properties button. Look for the boxes at the bottom of the Properties window that read "Show icon in notification area when connected" and "Notify me when this connection has limited or no connectivity" and make sure they are both checked.
  4. You could also right click on the Wireless Network Connection icon and click Properties from there.
  5. Open Wireless Networks tab Open the Wireless Networks tab and make sure the box labeled "Use Windows to configure my wireless network settings" is checked. Then click OK.
  6. under Control Panel\Network and Internet\Network and Sharing Center you could find "manage wireless connection" there you could assign/delete wireless connection.
Oct 26, 2014 | Lenovo ThinkCentre M72E 4004-B8U Tiny Form...
Will not power on
look for switch in back near power cable plug in.
Mar 22, 2014 | Lenovo ThinkCentre M72E 4004-B8U Tiny Form...
Ibm thinkcentre cpu fan runs on high after shutdown
Open the Control Panel. Power Options, Change/Adjust power off settings, change Sleep and Hibernate to Never, set to High Performance. A reboot everyday will reset your computer.
Jan 18, 2013 | Computers & Internet
Lenovo tiny
User manual here:http://support.lenovo.com/en_GR/downloads/detail.page?DocID=UM014622
Nov 28, 2012 | Lenovo ThinkCentre M72E 4004-B8U Tiny Form...
Install ram
Hi
the ram is normally stored under the bottom of the laptop under a small cover.
you have to remove the small cover and the ram is held in by two clips lift the ram up to unclip it from the frame.
cheers
IBM ThinkCentre 8183 (M51) does not boot
I think it is more than likely your hard drive is the problem, you get the splash screen and everything is working up to that point which tells me the motherboard is fine.
Jul 07, 2012 | IBM ThinkCentre M51 PC Desktop
Is the power supply for a ThinkCentre S51 8172 a standard atx power supply?
No, it's a custom size one. You need to replace it with an identical one.
Apr 09, 2011 | IBM ThinkCentre A51 PC Desktop
Lenovo ThinkCentre® A51 PC Desktop Logo
52 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
