Question about Porter Cable Air Tools & Compressors
Porter cable cffn25 won't run. Trips breaker
My Porter Cable compressor had a leak causing it to run all night. It now trips the breaker immediately when I turn it on??
    Genius:
  • 1,198 Answers
The little compressors were not built for continuous duty. The pump probably seized, or the motor burned up, or both.
Posted on Nov 26, 2013
SOURCE: Extra fitting on my Porter Cable?
The porter cable compressor is equipped with a pressure relief valve. Mine has a ring attached to it. When you pull out on the valve, it releases all the pressure stored in the tank. Try pushing that valve back in, or if faulty replace it.
Posted on Jun 07, 2009
webxcreation
  • 4 Answers
SOURCE: Porter cable pancake unit blows air after shut off.
tap on the check valve with a metal object. Its sticking open. The check valve is the brass fitting on top of the tank. When the valve sticks open it emits air from the area of the engine. If that doesn't work (which I would be surprised it doesn't), you'll need to purchase a new check valve. Good Luck!
Posted on Jul 02, 2009
  • 122 Answers
SOURCE: i have porter cable air compressor c3151-1 it
Mine did the same thing and it was the pressure switch.
Posted on Feb 02, 2010
SOURCE: Air compressor starts slowly and then trips 20 amp breaker.
jsd
Posted on Mar 07, 2010
cool78259
  • 228 Answers
SOURCE: Have a Porter Cable 175 PSI, 25 gallon upright
On these larger compressors, the motor that turns the compressor,
will have one or two capacitors, the capacitor in conjunction with the
motor gives the compressor that extra push or torque that is required
to get it going. if the capacitor goes out, the compressor will not work,
the motor may work but will not have the strength to turn over the compressor..
depending on the size motor, it may be mounted on top, on the side or
even in a juntion box attached to the compressor, if you have to replace one
i recommend powering down or unplugging compressor and handle the
capacitor carefully, use insulated tools or gloves, a capacitor is like a battery
it will hold a charge, but like a battery it can be discharged, the only difference
with a battery and a capacitor, on a capacitor you can have thousands of volts.
it can be replaced just handle it safely, good luck!
Posted on Jul 12, 2011
My porter cable 200 psi air compressor will not run
The curcuit breaker on the motor. Probably a little round button that's about the size of a screw head.
Jan 04, 2013 | Porter Cable Air Tools & Compressors
Porter cable compressor electrical smell won't run
wow
Check motor and pressure switch for erosion, electrical strikes in plastic
Replace if bad
Dec 31, 2012 | Porter Cable Cable 4.5 Gallons 150PSI Job...
Trips breaker after a few seconds of run time.
Start capacitors are disconnected when it is reach a full RPM.
Use a AVR tester - measure AC voltage across capacitors. It shall be off in a few seconds after is running.
If not - centrifugal switch or its components are problem.
Nov 28, 2012 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
My Porter Cable Job Boss compressor won't shut off. It builds up pressure but just continually runs.
Pressure switch - replace as soon as possible
Overpressure would be possible in that tank - it is dangerous !
Oct 20, 2012 | Porter Cable 4 5 Gallons 150PSI Job Boss...
I have a C2150 4 gal compressor from Porter cable with 2hp peak and 1.2hp continous rated motor. The problem is that I can not run the compressor on a 15amp circuit with out tripping the breaker. It even...
Try to use a higher amperage extension cord.
This unit is rated for 15 amps. It should be able to run on a 20 amp circuit unless there is voltage drop due to small wiring. Try an air conditioner extension and let us know the result.
Gary
Dec 19, 2010 | Porter Cable C2002 150 Psi 6 Gal...
I have a porter cale C5101 compressor. It hesitate to auto start when the pressure is low, always trip my circuit breaker.
What amp breaker do you have this hooked to. I would use no less than 15 amp ,preferrably a 20 amp. Next do you drain tank after use on a regular basis. If you don't moisture can build up inside tank and cause hard starting on automatic. If you need to drain tank there should be a drain valve on bottom of tank. try turning it counterclocwise with compressor off. If it dosen't turn that way try clockwise,air and moisture should drain. If you have alot of water in tank then shut valve and turn compressor on and bring to full pressure,then repeat draining procedure until no more water comes out. Hope this helps. Thank you
Nov 12, 2010 | Porter Cable - Cable C5101 Oil Free...
My c3151, loads to tank fine then the unit will cut in and out. The unit will trip a breaker. Is this an easy fix?
the line from the compressor to the tank should have a check valve .so that the compressor head does not have pressure for easy start up... check and replace if needed. when compressor attempts to start its to dificult with the pressure, causing circuit overload.
Jan 12, 2010 | Porter Cable Cable 4.5 Gallons 150PSI Job...
Air Tools & Compressors Logo
102 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
