Question about DeLonghi TCH7590ER Ceramic Electric Heater
Lights on but won't work
My heater light is on but will not send out any heat. Cleaned the filter still not working. What could be wrong with it
Gas heater won't run
Igniter could be burnt out.Mine looked good but it had less than a milliliter crack in it. Replaced it and works now.
Feb 27, 2017 | Heating & Cooling
Filter light keeps beeping
GE knows there is a problem with this and will send a serviceman out with parts to fix free of charge even if you are out of warranty as I was. Just call them at 888-443-4394
Jul 07, 2013 | General Electric GE GeoSpring Hybrid Water...
All lights flashing that the filters need cleaning? all filters cleaned? could the inside be frozen!!
Quick searech on Google reveals that people are saying it only works in Summer, unless you put heater nnext to it to warm up the heat sensor, mental!
Dec 04, 2010 | Candy CDV262 Dryer
I recently filled my Clearwater Spa with water, cleaned the filter and turned it on. I think the Z0-300 ozonator purple light was on when I first powered it up, but am not certain. The Balboa DE-L201...
check voltage to low speed pump if ok bad pump with all pumps going its moving water to heat when on low only not enough pressure check recirculation pump also its connected to heater
May 10, 2017 | Balboa Instruments Duplex Digital Panel 2...
Will light and run for about ten minutes then shut down
the home heating fuel will gel thus the heater will shut down
Jan 16, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Hi the my filter light keeps flashing and iv got no heat!
My guess is that the heater element has gone out. There could also be a lint clog in the exhaust vent...it takes air out through the filter...across the heater element....and back through the tumbler to heat the clothes. This is usually what causes heat elements to go out is the excess lint that gets on them and causes them to overheat and burn out!
Dec 14, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Feb 25, 2008 | Carrier 52PQ307 Wall/Window Air...
Heater comes on but quickly over heats.
There is no Filter On this Model. Check to make sure there is Dirt in the Flow way of the two towers. if that is not it the back up fuse in the heater is going bad.
Jan 16, 2008 | Holmes Products HCT460-U Utility Heater
DeLonghi TCH7590ER Ceramic Electric Heater Logo
47 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
