Question about Hotpoint Dryers
Hotpoint dryer will spin but stops with only few items in
When i load my dryer with minimal clothes it wont spin
    Sergeant:
  • 479 Answers
Sounds like you might need to replace the belt
Posted on Nov 25, 2013
Buffalo12980
  • 625 Answers
SOURCE: Hotpoint condenser dryer ctd00
change the drive belt. evidently the belt has stretched to the point the belt tensioning device can no longer do its job. when you change the belt make a diagram of which way the belt is reaved through the tensioning device. if you don't you'll be back here asking how to arrange the belt.
Posted on Jun 19, 2008
jumptrout51
  • 3361 Answers
SOURCE: Burn marks on clothing
The front felt drum seal may be bad. It is attached to the front panel, around the door.
Check and or replace the rear drum support it has worn down the ball and cup support. It will soon begin making a grinding/squealing noise.
When it wears and drops down the gap is greater at the front around the felt seal. Laundry gets caught in the gap and scorches.
Posted on Apr 20, 2009
  • 24 Answers
SOURCE: The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
Posted on May 19, 2009
  • 17 Answers
SOURCE: when the dryer is open the dryer keeps spining and wont stop you have to unplug it
Check the door switch. If the plunger is stuck, the dryer keeps running.
Posted on Jun 09, 2009
graemevm
  • 519 Answers
SOURCE: fisher and paykel clothes dryer wont turn with clothes in it.
Hi
Most dryers work with a belt around the drum. Either the belt is stretched and needs replacement or there may be a belt tensioner which needs adjustment to tighten the belt.
What is happening in your case is that the belt is slipping on the drum as it is too loose.
Best wishes,
Graemevm
Posted on Jun 18, 2009
Wont spin
have you cleaned the filter
if you have
change the motor brushes
Mar 10, 2014 | Hotpoint Aquarius WD63 Front Load...
Hi, My hotpoint wm 25 wont spin? Brushes are fine. Help!
Why no spin?..Is the water fully pumped out, is it out of load balance? This happens when too few items are in the drum the machine senses this and will not spin.......Hope this of some help
Jan 08, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
The door wont open
If it is digital which most new models are, you will see that after a spin cycle is completed it will take just a few minutes or so to release the safety, or some models you can go ahead and push the stop button and it will release
Aug 11, 2010 | Hotpoint Aquarius WD63 Front Load...
My hotpoint washer/ dryer is not spinning properly and the clothes are coming out soaking wet?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 19, 2010 | Washing Machines
Dryer wont tumble when loaded.
check for a "glazed" drum belt or a broken "idler" pulley near or on the motor that keeps the belt tight on the drum
May 10, 2010 | GE DBXR463GB Gas Dryer
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Ive got a hotpoint electric dryer that intermitantly blows hot air..in other words sometimes it wroks while other times dosent blow that much needed hot air to dry clothes..ive tried different things like...
Sounds like the drum is not turning under heavy load.this is a common problem with dryers but usually easily remedied if a competent diyer. first check the theory by putting in big load and see if drum turns. if not then replacing capacator should cure it.
Nov 06, 2008 | Dryers
Not rinsing or draining properly
Hello Kate,
Chances are the drain system ( filter, hoses, pump or your house drain ) is restricting water flow out of the washer..Try using 1/3 to 1/4 of the detergent you normally use for a while ( it must be HE grade and not std because Std will suds up way too much). Clean the filter and run a few wash loads with only a few items in there.. You can stop midway thru and add a cup or two of white vinegar to clean the inner works of deposits.. run a few wash loads like that .,. then from now on..use HE detergent, and only a very small amount. DO NOT FILL THE DISPENSER TO THE FULL LINE.. Hope this helps.. Please get back to me if you've tried these things and you are still having a problem,..
Sep 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
43 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
