Question about Microwave Ovens
Umc5200bab w s
Screen is on but does not function
  • Microwave Ovens Master
  • 2,113 Answers
Open it up. Look for burned wires. look at the main circuit board for overheating or burned components. Likely you didn't find anything. Check the thermal cutoffs for continuity. Likely the only part you need is the magnetron.
Posted on Nov 25, 2013
Sharp TV Model LC-42D64U.
Use the button called View Mode on the remote to go to the menu for this function
Apr 22, 2014 | Microwave Ovens
I have a sharp R 350 l. when i switched it on to heat some food it ran for about 10 secs then a loud bang.All functions work except that it wont heat anything.
Sounds like an electrolytic blew, but it could be any number of things. (Failure of one element could cause the failure of others, such as the magnetron, as well.) You could have it looked at, but if it's an inexpensive table-top microwave, it's less expensive to just go buy another.
Apr 13, 2014 | Sharp Microwave Ovens
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave model UMC5200BAB display is locked. After power reset per instructions display shows error code -SE- or -5E-. Somtimes pressing Stop for few seconds bring the clock back and it work fine for a...
"SE" error means you have a shorted membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs
Oct 08, 2010 | Microwave Ovens
Cannot read the touch screen & only easy minute works
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
You can also download the owner's manual from the page at the second link.
Jun 06, 2010 | Dacor DMT2420SS Microwave Oven
Screen goes black
It's a power save function. You can adjust it. If it's a pc go to "contol panel". There will be help there.
Mar 27, 2010 | Danby DMW119 Microwave Oven
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Kenmore elite microwave is not working. code F3H apeared after trying to run "baked potato" setting. no functions operate, display screen functions normally.
I unplugged the microwave for a few inutes, and let it reset itself. found solution on another site that DID NOT CHARGE ANYTHING for people to share solutions with each other!!!!!!!!!
Aug 02, 2008 | Elite Microwave Ovens
What would cause the touch panel display screen on our model gh6177xpb3 microwave to not function - the panel lights up - the lower controls seem to function properly - Thank-you in advance for your...
It may be a glitch that can be corrected by a hard reset. Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
It may have gotten moisture, contamination, or grease inside, which can happen if one cooks on the stove top without having the microwave's hood vent fan on.
It may simply need repair.
We repair microwave control units and touch panels / touch screens for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jul 26, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
