Question about Hotpoint Ultima WF860 Front Load Washer
Washer dryer - dryer not heating up
I've replaced the element and still no heat but not sure which thermostats/sensors I would need to replace to see if it's those,
  • 2,113 Answers
Before you replaced the element did you test the receptacle for 240 volt? Did you turn off the breaker and turn it back on to reset it in case one side tripped and it wasn't visible?
Posted on Nov 25, 2013
Testimonial: "Hi, no, haven't tested the source and I'm assuming I'd have to buy a tester? The breaker, what's that?"
  • 209 Answers
SOURCE: hotpoint wd62 washer dryier (aquarius 1200)
i am a retired engineer of 20 years, and its about a year since i worked on combination washer/dryers but if the heater elements fine and power comes from timer there must be cut out somewhere around where it should warm up, look all round the machine one may be hidden or hard to spot there maybe about 3 one of them one of them could be a trigger device (you can press a button to reset it) that style is a very small cube about the size of a sugar lump with2 spades on it, others look like a small flat oval or round shape the size of a five pence piece with 2 spade wires on them, remove the plug from wall and remove these spades and check the contacts for continuity, you need not remove from machine to do so, no circuit + no heat, replacement item not expensive, thats where to start based on the information given, check the sensors you mention again, it sounds like your so close, good luck and work safe
Posted on Sep 09, 2007
wagdom
  • 64 Answers
SOURCE: washer dryer not heating up
both the 'wash' & the 'dryer' have their own heating elements, If the 'wash' completes its full cycle including 'spin', then I suspect this heat element is ok.Re the dryer, most likely the heat element circuit is 'open circuit' somewhere, could be  the element, thermal fuse, thermostat, or a wire burned out
Posted on Oct 23, 2007
  • 958 Answers
SOURCE: Hotpoint Aquarius Washer dryer WD64 Not Heating Wash Water
hi pw82,
its seems you're doing your home work. that cylindrical part is the thermostat itself. it should have a resistance in the range of kilo ohms. around 10 kohm to 25 kohms. you can try to change the range of your testing equipment so that you could be sure that te thermostat is really open circuit.
if there is no resistance, then that is the problem. if there is resitance in the kilo ohms range then it could still be ok and you need todo some further testing.
you can check for voltage presence at the terminlas of the heater. if there is no voltage then it could be the relay on the power board that supply voltage to the heater.
or the board itself.
i hope i was able to help..please rate me..tnx
drcool299
Posted on Jul 11, 2008
  • 1462 Answers
SOURCE: Aquarius WD645 - dryer has stopped heating up
there is a safety device to prevent overheat. this can be a resetteble stat ie with a little button in the middle - press this button and there may be a little click as it resets. dryer will then work.
other type of safety device is a thermal fuse. this will be mounted on top of the dryer duct inside a sleeve. test for continuity and if open circuit, replace it
Posted on Sep 07, 2008
barkencoa
  • 3463 Answers
SOURCE: washing m/c water not heating up.
Make sure the economy button is not selected if it has one, as this bypasses the heater..
you say you have had element checked and seems o/k, to be certain it is o/k then test with a meter when it is on heat stage in the prog, and make sure you have a 240V reading across the heater terminals, if you have and it does not heat, then the element is faulty.
Plz rate my solution.
Thanks.
Posted on Dec 23, 2008
I have a Samsung dv220aew xaa dryer that does not produce heat. I've replaced the heating element, the thermistor, and the thermostats with the problem remaining, what could be the problem?
ARE U GETTING THE RIGHT AMOUNT OF VOLTAGE AT THE CONNECTION,? i VE SEEN IN SOME CASES WHERE THE MACHINE ONLY GETTING 120 AND WILL RUN BUT NOT CREATE MUCH HEAT? THE DRYER USES 120 TO RUN THE CYCLE BUT NEEDS A FULL 220 FOR THE HEAT CYCLE TO WORK, THUS IF UR MISSING VOLTAGE IT WILL NOT HEAT? ANOTHER CULPRIT COULD BE A BAD TIMER STUCK ON COOL DOWN OR FLUFF CYCLE AND WILL PRODUCE NO HEAT?
Sep 25, 2014 | Dryers
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
It's not heating and we've replaced to different heating elements
the dry is not heating up. we replace the heating element and thermostat and thermal fuse., It sill doesn't heat up
Nov 10, 2011 | Amana ALE866SB Electric Dryer
My he4T dryer is not heating at all. It is only cold air. What could this be so I know what part to order?
Hello there
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
function isValidEmail() { var emailAdd; emailAdd = document.all.infobar_EmailAdd.value; if(emailAdd == "" || emailAdd.indexOf("@")
Feb 01, 2010 | Kenmore HE4t 3.8 Cu. Ft. King Size...
My dryer will run, but will not heat.
Hello there
Heating Element
Thermal Fuse
Thermostat
Timer motor
Jan 25, 2010 | Speed Queen AES28AWF Electric Dryer
GE Front loader doesn't dry clothes completely.
Hello there:
f yourdryer won't heat up, it's possible that it is not being supplied withthe proper voltage. Here are three ways to make sure power is gettingto your dryer: First, make sure your dryer is plugged in. Next, checkthe circuit breaker panel to make sure all the circuit breakers are inthe correct positions. Finally, check to make sure no fuses in yourfuse panel are blown. Any of these could explain why power is notgetting to your dryer.
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 23, 2010 | GE DCVH515EF Electric Dryer
Heavy duty kenmore dryer model # 76680100 not heating up to dry cloths
Hello there:
please try this
Investigate these five areas if your dryer is not heating up:
Proper Voltage
Jan 19, 2010 | Dryers
The dryer does not give heat
Hello there:
Proper Voltage
8574d88.jpg Heating Element
d5b5af3.jpg Thermal Fuse
77d6bd4.jpg Thermostat
Jan 14, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer will not heat up, why?
Hello there
There are several reasons why a dryer will not heat up
i will do my best to explain them and i will add some links that you can use to help you out ok ?
If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irreparable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
Thermal Fuse
Thermostat
Timer motor
Dec 30, 2009 | Kenmore Elite 45986 Front Load Washer
Does not heat- three of the temp sensors read 0 ohms, one is at 7.4 K ohms. Can it be the cause
Hello there
Here is a list of item for you to check Hope this is very helpful for you
Best regards Richard
My dryer will not heat up. Investigate these five areas if your dryer is not heating up:
Proper Voltage
Dec 15, 2009 | Whirlpool LTE6234D Top Load Stacked...
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
