Hi I have Oska Gas Heater and Air Cleaner Model 43-540.
I have oska gas heater. I bought it from a shop. It was working there good. When i took it to home and tried to switch on. I get power on but when try to iginite its heater, it keep on working but didn't give flame/heat. It look like its gas line choked. Please advice. Khalid
  • 16,987 Answers
Gas pressure and type ok? What about the ignitor? Moving it might have caused issues with the ignitor.
Posted on Nov 25, 2013
4 Suggested Answers
yalmer
  • 552 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
SOURCE: We have an Everdure Brigadere
everdure econogas hot water system, model sd210. i'e got no hot water pressure anywhere in the house
Posted on Jul 20, 2008
vanni7
  • 163 Answers
SOURCE: my central heater is not
Hi!!! relax your flame sensor is bad change and you will be fine..If it turns off and on change your flame sensor4c9410b.jpg
Posted on Jan 05, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Need to know if my Rheem 21V30-6N water heater is approved for use in mobile home
ONLY if the air intake is located on bottom so air can be drawn from under the mobile home
http://waterheatertimer.org/How-to-install-gas-water-heater.html#manufactured
-Or- if your water heater has power vent that draws air from outside, usually through side wall.
-Or- if your water heater is installed outside.... good for warm climates only
Otherwise ordinary store-bought water gas heater draws too much air from the space, and cannot work properly in a mobile home.
Gene
Sep 30, 2014 | Water Heaters
Hi, I have Osaka Gas Heater model 43-540.
A natural gas heater can only burn natural and vice versa unless there are changes such as orifice and regulator. They can easily be converted to use either fuel, but you have to know what fuel supply you have, and what the appliance is set up for. Since you've already tried LPG, if it turns out the appliance is natural gas, then replace the spud (burner nozzle) before trying to operate it again. LPG cannot pass through the small nozzle hole in a natural gas appliance.
Nov 25, 2013 | Heating & Cooling
Nokia 206 ringer problem
salam sir mere pass nokia 206 ki first copy hai chaina main mainy oska ringer change kiya tha lekin phr bi koi farq nahe para mujhe ringer solution btay ringer main sirsarat a rahi hai
Feb 28, 2013 | Nokia WH-206 Headset - black NOKIA
Problem keeping my Rheem hot water heater light
What brand, model, and approximately how old is water heater?
This is important because water heater designs are changing quickly.
Did you remove door over combustion chamber to access thermocouple?
Newer Rheem water heaters have air intake under combustion chamber that has to be blown out using compressed air.
If this is different brand, then use mirror under water heater to see air intake.
Set water heater on bricks to avoid high water. Make sure drain line out of drip pan is 3/4" and terminates in good drainage location.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Put brass garden hose cap over drain valve.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Aug 29, 2012 | Rheem RHG Pro40-40F Pro Series Natural Gas...
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
I have Wiiliams direct vent wall furnace. I smell gas only when pilot is on and burner is not on. It does not smell when it is fully running (burner is on)
Dear Alex191: I am shocked and amazed that the Williams heater company is STILL knowingly and willingly selling faulty direct vent gas heaters. My problems took place in 1988! I bought a 30,000 BTU Williams DIRECT VENT from The Home Depot. I took the time to remove window sashes and run gas line to the Williams heater that I had placed in the window aperture. I was glad to finally have heat and be able to heat the area of the house where I stayed. Then I began to smell gas when the Williams was OFF. I traced it to the area where the pilot light gas tubing entered the combustion chamber. I removed the Williams unit and replaced it with an identical make and model and the SAME THING HAPPENED!!! I sat on my bed and almost cried. I had the gas company come out and they labled the problem as a "fuzz leak". The warranty repairman came out and had no idea what to do. Tightening the retaining nut did nothing. I called Williams and even back then they said that they were aware of the problem. They called me back and wanted to send me a part and asked me, "Can you work on it?" I returned the Williams and bought a Perfection-Schwank CONSOL heater that burns the air in the room and vents horizontally to a 4 inch vertical gas vent and was very satisfied with it. When they went out of business I bought an "Empire" brand gas heater. I don't know if I'll ever buy another direct vent heater from anyone. I will be glad to write an affidavit should you decide to suit the Williams company.
Feb 20, 2010 | Williams 1403622 Gas Compact Heater
No heat just warm air
I think you are on top of your problem,,you dont need any one elses advice.
Complete rebuild of the cooling and heating system,, simple.
Jan 19, 2009 | 2001 Oldsmobile Alero
Rinnai Econoheat 850 gas heater
Hi Daryl,
It needs a service. The jets carbon up and when they heat up they stop the gas getting through. If you take it to a Gas Shop they will charge you around 90-00 to service it and all they will do is blow it out with compressed air. If you can get hold of an Air Compressor with an Air Blower on the end you can blow it out yourself. Remove the Gas Hose from the back and place the Air Blower into the hole where the gas goes through and hold down the ignitor switch to open up the jets. Give it a good blow out. Once you have done that give the candles a blow as they eget dirty also. You will see a white dust more than likely come out of them. If you want to give it a good clean out remove the cowling and clean (blow out) the inside of the Heater. The cowling from memory has only about 6 or 8 screws holding it on. That should take the top and sides off. I can't remember if you can remove the lower vent on that model - if so it will only be either 2 or 4 screws. Hope this Helps.
Regards
Bryan
Jun 17, 2008 | Heating & Cooling
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
