Question about DeLonghi Prima Donna Avante ESAM6700 Automatic Coffee Coffee Maker
The Display on my Delonghi Primadonna isn't working.
Although the machine still works fine, I can't see anything on the display. Any idea which part will need replacing?
  • 4 Answers
SOURCE: DeLonghi EC701
Could be scale build up. Do you have well water? You should run a descaler or white vinegar through the unit often to keep the boiler outlets clean.
Unless you are saying that the pump just doesn't run, ie, no noise, vibration, etc. Then, thanks for the warning that their pumps are bad.
Posted on Mar 26, 2008
SOURCE: milk container won't fit onto front of machine
We had the same problem & worked out that it's because the actual milk container is too cold & has contracted from being in a cold part of the fridge. We moved the milk container to the door of the fridge ( it's a little warmer than the rest of the fridge) & it slotted in perfectly the next morning!
Posted on Aug 17, 2009
  • 81 Answers
SOURCE: My delonghi caffee nero machine-the coffee maker
If expresso maker part works, the fuse is ok. I think that the resistence of the hot plate is interrupted. You must use the guarantee's facilities. I think it is two years available.
Posted on Mar 07, 2011
  • 8 Answers
SOURCE: I have a DeLonghi ESAM
On this page there are some options for parts,
http://www.delonghi-accessories.com/index.php?cPath=448_83
There is also a phone number where you can call: 18008656330
Posted on Sep 02, 2011
caroldon
  • 17129 Answers
SOURCE: My DeLonghi EAM3500 display "general alarm" and
It is best that you contact the customer care of DeLonghi and post your request. you can also register your product for support.
The power supply can be sourced after the price is confirmed as these are available only with their spares department.
click on;
http://delonghiusa.com/support/
Posted on Oct 19, 2011
Where on the delonghi Prima Donna s delux coffee machine is the "coffee bean empty" sensor
look in the bin hopper for a clear panel and wipe it off good I hear they get dusty
Nov 20, 2015 | DeLonghi PrimaDonna S Deluxe Super...
I have a Delonghi PrimaDonna ESAM 6600. Just recently it stopped frothing milk. To explain fully, I have outlined the sequence of the fault below and resolution steps that I have already tried.
That sounds like the spout is blocked, when the pump goes quiet it is because it has built up pressure and the solenoid is barely moving. Have a probe up the nozzle and see what happens.
Jun 29, 2015 | DeLonghi Coffee Makers & Espresso Machines
Delonghi prima donna esam6600 the lcd display stop working
If you are proficient at working on these machines, you should be able to get a replacement display from your local Delonghi agent to fit yourself. The fault is likely to be in the onboard driver or the display itself. Simply replacing it should sort it.
Dec 08, 2014 | DeLonghi Coffee Makers & Espresso Machines
Delonghi PrimaDonna hot water not working
First I assume your machine is not too old? if it is,maybe you need to descale the machine as limescale can build up and block the outlet. If this does not solve the problem, it might be that the element has burnt out. New Machine!!!!!
Aug 26, 2014 | DeLonghi Coffee Makers & Espresso Machines
My Delonghi Prima Donna won't dispense milk only steam.
I've just had the same thing happen to me today. The one thing I noticed was there is a broken rubber ring which appears to have fallen from around the milk spout.
I'm off to the Service Centre tomorrow so will hopefully have some good news shortly...
Aug 23, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Just did a clean out of my coffee machine. Now it says insert grounds container! I do and it does nothing..could it be moisture in it? help.A
I had same problem with DeLonghi PrimaDonna. Three hours with the mentioned fan and the switch started working again.
Thank you so much.
Aug 21, 2009 | DeLonghi Coffee Makers & Espresso Machines
The coffee pot won't turn on anymore
burnt thermal fuse or heater does heater work under coffee pot? :)
Jul 03, 2009 | DeLonghi DCM485 Coffee Maker
Milk container won't fit onto front of machine
May 02, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi Prima Donna Avante ESAM6700 Automatic Coffee Coffee Maker Logo
21 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
