Question about Frigidaire ATF6000ES Front Load Washer
Water leak from model 110 washer - Frigidaire ATF6000ES Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Doris, thank you for your post!
I understand your washer model 110 is leaking. However, it appears above-listed model number is invalid. The serial tag, which lists your model number, is typically located on the upper front, as you open the door.
Is your washer leaking through the back, from the side, underneath? With this information I can better address the issue at hand. Thank you!
Posted on Nov 25, 2013
Leaking washer, increases when using cold, less when using hot. May be at drain?
Stop the washer and clean up the water. Confirm that the water is not leaking when the washer is off. The leak can occur before the electric valves either where the hose connects or from the electric solenoid valves just inside the washer. The situation is more likely true if the hoses are stressed by being bent to one side.
If dry then confirm if it is the hot or cold by running the machine with the cold service valve open and hot closed.
Jan 06, 2016 | Washing Machines
Washer leaking intermittantly while drainong
Take a look at this service manual. You model may be a little different but the process should be the same.
Nov 04, 2012 | Washing Machines
A Kenmore model 110 washer leaks while filling up
It is either going to be the tub gasket that is leaking, drain hose or the drain pump. Take a look at this video to show you how to get the cabinet open. Then, I would pour water into the machine by hand and find the leak. After you have done this, please post back where you found the leak and I will direct you to the parts you need and post a video to show you how to make the repair. This video is for a different model but the unit parts will be the same.
Oct 16, 2012 | Washing Machines
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
My Kenmore 110 92587210 Washer is slowly letting water in
The solenoid for the cold water valve has failed in the open position and needs to be replaced. The valve unit is for both hot and cold. It is the item that the water hoses are connected to.
Aug 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series, 110 washer leaks water when
Hi, You will need to change the inlet mixer valve. It is sticking open just enough to allow water to drip through it. This should be chandes asap so that it doesn't get bad enough to over flow the washer.
Here are directions on how to remove the cabinet so you can get to the inlet valve.
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 14, 2009 | Kenmore 22422 Top Load Washer
Leaking about 4 to 5 cups of water under washer on floor washer is about 17 years old model no. 110. 82872820
If the leak is in the middle toward the front it is probably the pump. The impeller can wear through the housing and create a leak. It can be changed quite simply, if you have the tools, I have the instructions. You'll have to remove the case. Let me know.
Jul 10, 2009 | Kenmore Washing Machines
Kenmore Model 110 top loading washer
May be the water pump! Give the model number in full.
Jun 09, 2009 | Kenmore 24032\24036 Top Load Washer
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
70 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
