Question about Panasonic Heating & Cooling
CU-D50DBH8 UNIT NOT RUNNING
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
DFBB363R (20.3 cu. ft.) Refrigerator Noise from rear of unit
Could be the compressor vibrating too much when it is running
Dec 04, 2013 | Viking DFBB363R (20.3 cu. ft.)...
FFPH31M6L 3.1 cu. not running
Hello Kevin, thank you for your inquiry! Do you hear the compressor running? If you do not, then the unit may possibly be experiencing a coolant leak or an issue with the internal sealed system, such as a faulty compressor, evaporator or faulty relay. From what I show, there do not seem to be any manufacturer parts available for this particular unit so this unit may or may not be serviceable. This could be because it is a smaller appliance, and repairs are often more costly than the actual unit replacement. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine your coverage and if there is any potential remedy in that regard. Best of luck!
Aug 12, 2013 | Frigidaire FFPH31M6L 3.1 cu. ft. Compact...
Unit gets no colder than 40 deg.
start with the basics. Make sure the condenser coil is clean. If the unit is running, make sure the evap fan motor is running. You may have to hold the door switch with your finger to check that out. Let me know and we can go further.
Sep 19, 2010 | Beverage-Air 23.1 cu. ft. / 654 liter...
True 49f goes into defrost mode the contact opens for the compressor but the compressor keeps running
in many cases, these units have relays or contactors where the contact points actually weld together. this causes the unit to stay running even though power to the coil has been stopped. I'd start looking there first. don't over look the possibility that someone could have mistakenly miswired the unit.
Aug 19, 2010 | True 49 cu. ft. / 1388 liter Commercial...
The freezer is slowly rising in temperature(0-18 deg in a week, still set at zero) and either side of the unit by the freezer door are very, very hot. Unit is about two years old. Fridge temp is slightly...
Check the condenser fan motor in the back, bottom of unit. pull off lower panel. Fan should be running when unit is running. Also check the condensor coils underneath or in back to make sure they are clear.
Jun 02, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Ice Cream Server
It is a dual thermostat unit. You could have a bad thermostat, giving you false readings.
May 13, 2010 | Caravell 5.5 cu. ft. / 156 liter Chest...
Stopped running, don't know where to start
First check to make sure you have 120 volts to the unit. If you have power to the unit you then need to check the temperature control to see if it works(closes) and gives 120 volts to the compressor. Does the compressor make any noise like it is running and does the compressor get warm or very hot. Try this first.
Nov 12, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Jun 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Heating & Cooling Logo
37 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
