Question about The Companion Group Kozy World Portable Companion Heater
Excessive flame on center grate - The Companion Group Kozy World Portable Companion Heater
  • 69 Answers
Excessive gas pressure. set pressure to makers spec
Posted on Nov 27, 2013
Adjust flame
Do not attempt to do this task yourself, you should call a Gas Safe engineer to solve the problem.
Jun 29, 2013 | Verona CTG424SE Gas Four Burner Cooktop,...
Excessive Flame on Gas Grill
blocked burner needs cleaning , air mixture needs more air /or less air .
Mar 29, 2012 | Weber Genesis Silver B Grill
How can i manually ignite the grill
What I do is remove the grates and flame guards and light the burners with a stick lighter then turn em on low and cover them with the flame guards then sit the grates back on there.
May 28, 2011 | Brinkmann Charmglow Stainless Steel LP...
While boiling water with low to med flame, the front right burner grate EXPLODED! Burnt hardwood flooring (since grate literally flew thru the air), melted adjacent thermafoil cabinet reveal & burnt MY...
wow never heard of that one.
what if when grate was cast,air bubbles inside of grate were formed,[fluke] and expanded and blew.
try with other grates,but put shield over grate somehow,like chicken wire,and hold on to stove with bricks or something.ps. stay back.
that sounds like a claim to me.
Dec 07, 2009 | Bertazzoni X366GGVX Stainless Steel Gas...
Heater has blue flame petruding above the grate.
hello there
there is a flame adjustment screw that needs to be adjusted
there should be a fuel valve that turns on the gas for the unit inside ofthe unit where the gas line goes in at there should be as a small brass round cover just after this under the cover has a flat tip screwdriver slot
insert the screw driver in it and turn counter clock wise to adjust ok
best regards rich
Nov 28, 2009 | GPS
GAS FLOW IS TO HIGH PILOT GOES OUT EXCESS GAS FLAME ON TAPPEN FU
Hi this could be a gas leak on the pilot i would get this checked out
Mar 17, 2009 | Tappan TGF320 Gas Kitchen Range
1600c vanguard propane heater, big flame on middle grate
Make sure the grate is in the holder like the others, and nothing is blocking the bottom of it. They often slip back where the fire misses the inside where it should hit.
Dec 22, 2008 | Vanguard International Infra Red - Large...
JGBP89SEMSS BURNER HEIGHT
Sounds right long as you did the conversion okay did you change the spring in the reg ? lp gas does burn lower than nat gas smaller blue flame . you could see if the aeration can be adjusted to the burners You could also check the pressure at the burners lp working pressure is 14in wg .
You could check the reg outside . That's all I got .
Mar 17, 2017 | GE JGBP88SEKSS Gas Kitchen Range
Heating & Cooling Logo
125 people viewed this question
Top The Companion Group Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a The Companion Group Heating and Cooling Expert? Answer questions, earn points and help others
