Question about Mitsubishi WD-73737 73 in. HD-Ready TV
Color changes on screen mitsubishi wd73737
When the screen came on it was washed out in color and then it became more like a color negative, after 12 hours turned on picture back to normal, is it the tube or a fan?
  • 373 Answers
The main board is going bad Located HERE
Posted on Nov 25, 2013
  • 68 Answers
Nothing of that i think it is the power supply some capacitors is bad or screen -tube -
Mitisbuski 73737 made popping sound and cut off
Check your lamp. The popping sound was most likely the arc tube exploding. Make sure you only install a real Philips or Osram lamp. WD73737 Mitsubishi Genuine High Quality Original Projector Lamps now...
These folks have good lamps.
Apr 28, 2015 | Mitsubishi WD-73827 73" HDTV DLP TV
Tv turns off by itself with an amber or red flashing light. lamp replaced about 6 months ago.
Should be a high voltage or power circuit problem,like transistor too hot,or any component short circuit.
Oct 29, 2012 | Mitsubishi WD73737
I have a WD-65737. The lamp gave out, so I replaced it. Now it will start, but generally after about 5 minutes of it running fine, it'll shut down and blink yellow
Where did you get the bulb. I tried a cheap one and it did not work correctly. I found a bulb dealer that had I believe had a warrentee of a year and I have had no problem since. I have a WD73737. the cheap bulb carrage was not quite to specs and did not fit correctly from bulb surface and there was a gap and color kept changing on screen. I got the bulb cheaper than Mitsubishi, aprox 75 t0 80dollars.
Sep 01, 2017 | Televison & Video
Hi, Is there a firmware update for my WD73737? If not, is one planned?
The firmware update, 11.03 is now available on the Mitsubishi-TV website.
Nov 19, 2010 | Mitsubishi WD-73737 73 in. HD-Ready TV
Wd73737 blinking green power light
my tv keeps turning off i have a mitsubishi wd-73737 what can i do to fix it?
Jul 12, 2010 | Mitsubishi WD-73737 73 in. HD-Ready TV
Tv will not come on. the green light on the front on the tv blinks, the blue screen come on and the tv shuts off. I've tried the reset procedure. I've unplugged the set for a while. Nothing works. The TV...
First the tv cannot be only 3 months old, (needs chassis rebuilt- send to mitsubishi they do it for around $300) and how did we go from DLP to adjusting screen levels and focus adjusment? PLEASE if you have limited knowledge you will be more helpful if you don't share it.Thanks
May 30, 2010 | Mitsubishi WD73727 73" HDTV
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65905 DTV is green
A compatibility issue rears its ugly head. The format that was to be back then has changed slightly over the years and this is what it's come to...Sorry...accordianman
Jan 04, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Lcd screen
That is an effect that can be had by internal software in the camera, like my Sony. Just get in there and turn off "negative" Youll probably see Sepia, solarize, B/W and negative as other choices.
Sep 18, 2006 | Olympus SP-500 UZ Digital Camera
Mitsubishi WD-73737 73 in. HD-Ready TV Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
