Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
All pro 60,000 kerosene heater wont start, igniter lights then cuts off. i cleaned fuel filter and air filter. and burner .. i dont know how to check or clean the photo cell.. any help
  • kenneth
    kenneth Dec 21, 2013
    i put a new photo cell on it..the igniter stays lit and i can see fuel spraying some even going on igniter but it wont fire it just shutts down..
  • All-Pro Master
  • 16,010 Answers
If you can get to the photocell, make sure that it is clean. To test it you need an ohm meter. Hook the meter to it and set the meter to read Kohm.. See what it says, then shine a light on it and see if the meter reading changes. IT should drop. If it does not, or the reading is really high, replace the photocell.
Posted on Nov 25, 2013
  • Brad Brown Dec 23, 2013
    IF that is the case then there may be too much kerosene coming out.
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have an All-Pro Model K100-FA heater, the
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 16, 2011
e-Guru
  • 3917 Answers
SOURCE: i have a all pro
Hi
First of all make sure that the heater is filled with K-1 kerosene. Other fuel, such as gasoline, burn too hot causing the heater to burn out of control. Never use gasoline or any other fuel described as flammable. If there is any question about the fuel in your heater it is best to drain it and replace the wick and start with fresh K-1 kerosene. If you are sure of your fuel and your heater is giving off sooty black smoke it is a sign that the fuel/air mix is off. Make sure the chimney is seated correctly. If it didn't seat into place correctly after lighting you may be getting a very high flame on one side. If it's a high orange flame all the way around try rolling the wick adjuster knob down within the adjustment range - the wick may just be too high. If these things do not fix the problem wait until the heater is cool and inspect the burner cylinder. If there are any holes plugged with soot it needs to be cleaned or if it's dented or buckled it needs to be replaced. After you have checked the fuel and burner you should check to make sure the wick is installed at the correct height. Refer to the owner's manual for exact height. If the wick isn't installed correctly or there is no obvious defect it is best to take the heater to a service center to determine the cause.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 26, 2011
heatman101
  • 43501 Answers
SOURCE: dynaglo forced air kerosene heater fuel not
heatman101
Posted on Jan 28, 2011
  • 4736 Answers
SOURCE: Problem with the All-Pro Kerosene
Here as link to your DESA International, ALL-Pro heater, Model # PK 60. Be sure to checkout the Trouble Shooting Guide.
http://www.desatech.com/manuals/Construction%20Heaters/113282-01.pdf
I'm sure this will help solve your problem. Please let me know.
Posted on Mar 07, 2011
Cant get my electric kerosene heater to light
Could the fuel be too old? I would recommend dumping the fuel in an outdoor firepit and burn it up. Use an inexpensive "Turkey Baster" to suck it out of the tank. Then put fresh kerosene in and try it.
Apr 01, 2017 | All-Pro Kerosene Garage Shop Heaters - All...
I have an all pro 60,000 btu flex fuel heater. all pro went out business. i need a new igniter .... can anyone help me find this part ?
Try www.desatech.com. From the main page, click on kerosene heaters. Some igniters should be at the top of the page that comes up. See if one matches yours.
Jan 14, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
My kerosene monitor heater with the model number M441 isnt workin correctly , ive changed the filter outside that goes into the tank and replaced the burner and still it isnt working , the burner status...
First thing to do is clean the flame rod. Take the black grill off of the front of the heater (6 ro 7 screws). Now locate the flame rod. It is beside the window where you can look into the burner. It has one wire going to it. Be careful so you don't damage the gasket. The rod goes in then straight down, so you will have to turn it to get it out. You can clean it with some steelwool or emory cloth. Reinstall it and try the heater.
Listen to the heater. If it cuts off, does the fuel pump start making a thumping before the heater cuts off? If it does, the heater is running out of fuel for some reason. I know you checked the filter, but did you check the strainer in the fuel sump. You can find it on the right side of the heater at the bottom. Make sure you turn off the fuel at the barrel before you remove it and have some rags ready to soak up the kerosene that will come out. Clean the filter with some kerosene if it needs it.
Let me know what you find and don't forget to rate my answer. Thanks.
Jan 06, 2011 | Heating & Cooling
I have a 60,000 btu kerosene heater its getting fuel and the glow plug turns on but still wont fire up n shuts down. what would cause this?
Well it is getting fuel but is it atomized in very small droplet form? If so is your igniter close enough to ignite the fuel? You see these spray a very fine conical mist under high pressure, if the mist is not defined or conical it sprays past the igniter. If it is fine and cone shaped it could be the positioning of your igniter. Please check both by removing the top section of the heater and watch what is going on in there. My thoughts are a bad nozzle and if you replace it pay attention to spray angle and GPH rating printed on the side of the nozzle.
Dec 22, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
An All Pro 60000 btu kerosene heater.
The fuel filter is clogged you need to clean it. Mine was doing same thing, easy fix.
Jan 05, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Heater wont start.Fan goes, Starts to heat, then blows a couple clouds of smoke and dies. Ive cleaned filter, new fuel. Cant figure out what adjustment I should be doing. Glow Plug? What else?
take the shield off and see if it burns with more combustion air. If it does then the heater isnt getting enough air. look for a shutter or set screw near the burner that should be the primary air adjustment. sounds like you have been working on the fuel side already. You may check the orfice to see if it is partially blocked, use a safety pin and gently **** it out. also check the burner tube
Dec 07, 2009 | Reddy Heater 60,000 BTU Kerosene...
HARD START AND BLOWING SMOKE
clean all of your filters and the spark plug and go back to useing K1 kerosene. Diesel fuel has a higher ignition temp. burns dirty and has a tendency to gel.
Jan 20, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
154 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
