Question about Midland 12-Mile, 22-Channel FRS/GMRS 2-Way Radios with Voice Activation LXT435VP3
What batteries(AAA) can i best use for midland LXT322 two-way rad
I've bought 2 midland LXT 322 2-way-radio's without batteries.i want to buy recharcheble batteries(AAA) with the highest milliamphere possible but i don't want to overheat them or something?wich must i use?
  • kevinjekautz May 12, 2009
    Exactly the answer i was looking for!!! GO PALABOY!!! thanks again man!
Midland extra talk lxt 328
Check your model number and download the manual from here: https://midlandusa.com/two-way-radios/support/owner-manuals/
Jun 07, 2014 | Midland X-TRA TALK GXT400 (7 Channels)...
Midland lxt 328
Jun 07, 2014 | Midland LXT303-A 2-Way Radio
I bought 6 sets of Midland LXT 345 walkie-talkies for the teachers to use when they go out on the playground. Less than 1 year later several of them don't work. They keep them in their charges when...
The batteries have likely been damaged from being on the chargers too long. Try trading a known good battery into the non-working radios and see if it/they will work with a good battery. If so, replace your batteries, and then only put the radios on the charge when they need a charge, such as after the radios have been used 8-10 hours. Longterm charging can quickly age batteries. Life expectancy of a battery is 18-24 months with good care.
Best regards.
Sep 23, 2011 | Midland LXT385VP3 Two Way Radio
How could i change its batteries?
  • Your radio, Midland LXT110, utilizes a NiMH rechargeable battery pack or 3AAA batteries. I have a similar set and when the battery pack runs out I just use regular AAA rechargeable batteries. They are more economical. To change the batteries in general follow these steps.
  1. Remove the back clip.
  2. Now remove the battery cover by pushing down from the top center of the battery cover and slide it off.
  3. Replace batteries observing polarity.
  4. Replace the battery cover.
  5. Replace battery clip.
Regards, Tony
May 17, 2011 | Midland LXT110 Two Way Radio
How do you change batteries
1. Remove the belt clip from the back of the radio. (Push spring clip at the top away from the radio, then slide the belt clip up and off).
2. Remove the battery cover by pressing down on the top center and sliding the cover down and off the radio.
Need the manual for your radios? You can download and print it, at no cost, here:
http://www.buytwowayradios.com/Products/Midland/manuals/LXT-110-manual.pdf
Oct 28, 2010 | Midland LXT80 Two Way Radio
My Midland xtra talk lxt 320 is not working properly. Once I turned the radio on it just started buzzing. For some reason I can't turn it off. It also says rx at the top right hand corner. On my another...
Try replacing the batteries with a good set of alkalines. The standard batteries that come with these radios are of poor quality and get weak very shortly after purchasing these radios. The radios will have the symptoms you described when the batteries are weak. At least this has been my experience having these radios.
Jul 20, 2010 | Midland LXT310 2-Way Radio
I can't get the 2 way radios on the same channel
Press the Menu button. The channel number will flash. Press the adjust keys to select the channel number. Press the menu key again and the Subchannel number will flash. Set to desired number. Then press the push-to-talk key to get out of menu mode. Repeat with second radio and be sure to choose the same channel and subchannel. Then adjust volumne as needed.
have fun!
Nov 19, 2009 | Midland LXT310 2-Way Radio
i need a manual for a lxt 322 2 way radio and it just had AAA batteries in it is that okay?
May 08, 2009 | Midland LXT310 2-Way Radio
Can't figure out how to get a "channel" to lock on the handset
Here is a link to the owners manual for the LXT-330 420 Series radio:
http://www.hitechwireless.com/pdf/Midland/LXT-330-420 Owners Manual.pdf
I hope this helps.
HiTechWireless.com
Mar 27, 2009 | Midland LXT410 (14 Channels) 2-Way Radio
Radio Communications Logo
135 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
