Question about Symbol MC9090 Barcode Scanner
Sybol scaner 9090 keyboard not working - Symbol MC9090 Barcode Scanner
When i migrate tally7.2 data to tally erp9 error occur migration is unable to reach tally erp9 server
This Error with migration of data occurs when the connectivity is not proper with the Tally ERP ODBC. It includes the IP:Port.
The Default port for Tally ERP is 9090.
To change the port go to the installed tally ERP 9 folder. Click on Tally file type Configuration Settings, open it with a text Editor i.e. Notepad. Somewhere at the bottom will be ServerPort. Change the ServerPort to 9090. The migration will work. I have tested. Works fine with me.
Apr 26, 2012 | Computers & Internet
Symbol MC9090 I formatted the Symbol MC9090 installed the drive after I do a setup on the device everything works correctly, after rebooting the symbol mc 9090 its configuration is...
this is because you are cold booting the unit. Everytime you cold boot a 9090 it re-sets all saved settings. You need to warm boot only unless you want the unit reset to default. any problems please mail technical@codeo.co.uk for support - we supply MC9090's in refurbished condition complerte with like new warranty incase you need any
Oct 21, 2011 | Zebra Symbol Technologies MC909X-G Series...
Letters dont come up as typed
If something different than what you typed comes up, then it is probably the keyboard settings that are to blame, if nothing at all comes up then it could be a loose connection between the keyboard connection to the motherboard.
Mar 21, 2011 | Acer Aspire 5520-5908 Notebook
Keyboard is pringting out the blue symbols not the white sybols how do I fix
Sounds like the Num Lock is on. Hit the Num Lock key, see if that helps.
Regards.
Jun 27, 2010 | Gateway 2520915 Keyboard
The symbols above the numbers on my keyboard just stopped working. Would this be a hardware problem or a technical one. I am using someone else's computer to send this message as I am unable to get into my...
Hi, I'm guessing you have tried using both the left shift and the right shift?.
if one works and the other doesnt I'd say the keyboards stuffed.
If its a funky multimedia keyboard there perhaps may be some key/button to enable/disable shift and or special characters, but I have never seen a keyboard like that.
Do all the numbers and alpha characters work, its just to sybols about 1 to 10?.
This is a wireless keyboard?
Maybe reset the keyboard, normally the base unit and the bottom of the kboard and mouse have a reset/reconnect button, worth a try but I suspect it wont help.
Trying new batteries probably wont help either but probably worth a try.
Failing that, I'd plug in an old usb/ps2 keyboard into your pc and see if that works OK (you'll need to reboot first if its a ps2 keyboard), just to rule out any strange software issues.
All that said however, I suspect you may be looking at a new keyboard.
I do think its worth trying the above first though.
Good luck.
joshAU
Jun 16, 2010 | Gateway 2520915 Keyboard
Keys not functioning properly. Typing wrong sybols
You can reseat your keyboard's cable. You will need the manual of your computer to do this. If reseating the cable will not work then you may have to get it replaced.
May 11, 2010 | Acer NSK8458AN Keyboard
Can not get the question mark to work
turn off your PC and check all the connection are OK
then restart the PC
start >> Run > Notepad
there you check all keys of your keyboard
In case any of the keys are not working you will come to know.
Secondly
meanwhile you can use the Alt code for typing
Alt 63 ?
Alt 123 {
Alt 125 }
Like that
all the best
like that
Jan 07, 2009 | Logitech 967437-0403 Keyboard
Symbol MC9090 Barcode Scanner Logo
54 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
