Question about Mint Automatic Floor Cleaner
Mint floor cleaner not charging - Mint Automatic Floor Cleaner
A friend has a rechargeable vacuum cleaner model no. RHSV1C and cannot find where to put charger in. I have tried the charges she has
This model has a separate charging station that mounts to the floor or wall. You plug the charger into the charger station and then connect the vacuum to the charging station. I hope this helped.
Jan 27, 2018 | Vacuums
Tip
Dyson DC39 / DC37 with Musclehead floor tool - Getting started
<utube src="wVy8e0CSmy4"></utube><br>How to assemble and use your Dyson DC39 or DC37 vacuum cleaner. This applies to all variants supplied with the Musclehead floor tool.
on Aug 19, 2013 | Dyson DC39 Vacuum Cleaner - Multi Floor...
How do robotic vacuum cleaners work?
They continually suck air, when they hit a surface change automatically change direction to clean overall all accesible places.
Sep 06, 2016 | Bissell SpotBot Robotic Wet/Dry Vacuum
Why is there a red light
Is the red light blinking? Are there any beeps or tones? If so how many beeps?
Jul 07, 2014 | Mint Automatic Floor Cleaner
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
I have no spray on floor but have spray at hand
Same Bissell 9500 cleaner. Hand piece works fine, but cant spray water / cleaner when doing the floor. I've made sure the rollers are working and taken my air compressor on low psi and blown back to make sure the floor spray lines are clear...
Going to take apart and check the pump today.
Still looking for help! Thanks
Sean
Apr 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Mint Automatic Floor Cleaner Logo
61 people viewed this question
Top Mint Vacuums Experts
Are you a Mint Vacuum Expert? Answer questions, earn points and help others
