Question about Samsung AS1293L Air Conditioner
Rapidly turns on and off
Ac unit rapidly turns on and off.
Thank you for your solution , water condensation is backing up in the bottom of the unit and over flowing in to the house. yes the problem is there can i rectify with your guid line or have I go for techincal supporter.
Posted on Oct 17, 2009
    Sergeant:
  • 201 Answers
Low pressure cut-out is active.unit needs recharging.
Posted on May 08, 2009
What would cause my a/c comp to cycle rapidly at idle it also causes my temp gauge to bounce back & forth
A low refrigerant charge would cause rapid compressor cycling. If your engine temp is rising with AC, check to make sure the AC radiator fan is running when AC is on
Jul 01, 2017 | Cars & Trucks
03 Honda Accord v6 left turn signals not working. So I try another flasher relay. Now no turn signals, hazards, or radio/ac lights. ???
It probably blew a fuse.
Flasher unit would not cause one side only to stop working but instead check the switch, wiring, connections and both bulbs.
A little used hazard warning switch is often the cause of strange or unusual flasher behaviour. A couple of minutes of rapid operation often works.
Jun 01, 2016 | Honda Cars & Trucks
How to fix rapid flashing turn signal when all bulbs are OK?
Easy way to find the location of the flasher unit: Turn on either the RIGHT or LEFT indicator, and listen for the click under the dash. When you find the source of the click, THERE'S THE FLASHER UNIT! :)
May 13, 2015 | Cars & Trucks
Mr slim ac shuts down and restarts to frequently.
Changing the setting won't affect the way the unit works, only how long it runs for. Rapid switching off and on will kill your compressor in time - check the refrigerant level. Usually short cycling on lp switch.
Oct 19, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
Ac won't blow any air
Good Morning David - Here are some simple troubleshooting tips to help resolve this issue:
If the outside temperature or inside temperature is below 60 degrees, the unit may not run.
Confirm that the unit has power to it.
Check the power cord connection to the wall outlet is secure.
Make sure that the house circuit breaker has not tripped.
Make sure the unit is turned off, Press the TEST button, you will notice a click as the BUTTON pops out. Then press the RESET button. Again, you will notice a click as the button engages, now turn unit on. If the LCDI plug does not reset the cord may be damaged.
The "Cool" circuit has an automatic 3-minute compressor time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping and the fan will continue to run during this time.
If the unit has been turned off and on rapidly or if the thermostat was changed to a lower number and then immediately turned back to a higher number the compressor may not start. You must turn the unit off and wait a minimum of 3 minutes for the unit to equalize before restarting.
I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Jul 09, 2013 | Frigidaire Heating & Cooling
2004 Jeep Overland rpms go up and down at a steady speed
Turn off the AC system and see if this stops, it may be due to the AC compressor cycling rapidly due to a low charge of refrigerant..
Jul 13, 2012 | 2004 Jeep Grand Cherokee Overland
MAXTOR Personal Storage 3200 - LED light rapid blinking
Many experts beleave you got a bad AC adaptor the plugs into the wall. My findings are the following.
If you hear the drive spin up but does not show up on your computer then you got a bad controller board inside the case of that hard drive. The fix take the drive out of the enclosure and put it into another enclosure or simply install it into your computer.
I have videos on a WD mybook witch is not the same model or manufacture but still helps some people figure out what to do. Please be considerate i mean the videos are dark but you can still make out on whats going on.
http://www.fixya.com/support/r3574054-external_usb_hard_drive_data_recovery
Now you can try a AC adpator for this unit some ac adaptors do fail but in most cases its the little usb to sata connector inside.
good luck with this and please do be considerate and rate.
Apr 28, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
How to turn off calculator
press shift then the ac/on button
Aug 17, 2008 | Casio fx-300ES Calculator
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Weird Rapid Metallic Popping Sound
I think i have the same problem, but i can get audio still. did the poping plinking sound come from the inside back panel of your TV? it sounded almost like a arc wielding noise?
Sep 29, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Samsung AS1293L Air Conditioner Logo
132 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
