Elonex tv keeps going onto standby, take about 10-15 goes to work.
When switching tv on keeps going onto standby, eventually it then goes onto elonex screen but flicks off again onto standby. This keeps doing this for 10-15 times then eventually works. This is now getting worse sometimes 20 times before this works.Help any solutions?
    Scholar:
  • 171 Answers
Sounds like you may have some capacitors going bad. If it is a high end TV it may pay you to take it to a repair shop.
Posted on Nov 25, 2013
  • 111 Answers
SOURCE: no power off charge
It is evident your Battery is not working - If it is not too far gone which it quite possibly is follow my steps to fix the battery and allow it to hold charge:
1. Remove the battery from your Laptop - In a lot of cases there will be a slider on the bottom side of your laptop that will unlock the battery and allow it to be slid out.
2. Put the battery in a think plastic bag - Alternatively 2 thin plastic bags
3. Place it in the freezer for 30 minutes
4. Remove the Battery and place in in the sun for another 30 minutes
5. Place it back in the freezer for 30 mins
6. Put it out in the sun for 30 minutes then back into your laptop.
7. Leave the battery plugged in to charge
8. Remove the AC Adapter
Please Note: I work full time in the IT field I use this technique to fix batteries that do not hold charge as it puts the energy in stasis and wipes their theoretical memory - It works for laptops with little charge holding capacity but as your's has no charge the probability of it being dead is high under this circumstance I can only recommend attempting to hunt down a replacement battery at your expense;
I sincerely hope this write up has helped you,
Blazamane
Posted on Jan 07, 2009
RescueTechLA
  • 2653 Answers
SOURCE: elonex laptop
I love Christmas. What's going on with the laptop?
Can you give me some details?
Posted on Mar 04, 2009
Geekman
  • 32281 Answers
SOURCE: elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 10, 2009
SOURCE: how do i connect using
You need to install the drivers for your specific wireless card. These can usually be found on the manufacturers site.
Posted on Feb 28, 2011
SOURCE: elonex eb500 won't turn on
My guess is that firmware update failed on Win7. Try the same thing on WinXP. More information available at:
http://www1.elonex.com/support/products/ebook/500eb-firmware.shtm
Posted on Nov 29, 2011
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
How do i fix my elonex tv
switch off.wait for 5 mins.
press & hold power button till it turns on then off.
ifno luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
May 04, 2014 | Televison & Video
Elonex tv keeps going on standby, take 10-15 times for it to work
It sounds that there is some short circuit with its SCL-SDA rail, at its main digital circuit board. It will be best to contact any service technician, as troubleshooting the main board is a skilled work.
Nov 25, 2013 | Televison & Video
Elonex "10.2 laptop frame broken (not the screen)
Try ebay. Just but in the search box "Elonex LCD Bezel". The are easy to replace. Most screws on the Bezel are hidden by a rubber bumper or something that you can use a safety pin or real small flat head screw driver to pry off.
Mar 23, 2012 | Computers & Internet
Elonex eb500 won't turn on
Nov 22, 2011 | Computers & Internet
Cant connect to internet with an elonex one+
for support call (0871 90 296 90) or email support@elonex.co.uk info from: http://www.elonex.com/support/contacts.shtm
Jan 17, 2010 | Computers & Internet
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
No Signal after 30 Mins
Posted for a similar problem:
This is an issue with IC 803 on the Z board. This is a 3.3 V regulator that supplies this voltage to the slot card cage. Most input boards use this voltage EXCEPT the component board which is why it keeps playing along whike the DVI, HDMI, or composite signals will cut out after warm-up.
This is a surface mount multi-pin IC and is a bit tricky to replace.
The entire board is PN# TNPA3198xx with suffix determined by what model 7 series plasma you have.
This was a problem from around Nov. 2004 to Mar. 2005
T Wiz
Sep 22, 2007 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
