Question about Samsung Cameras
I want to set my photos to 1MB - Samsung Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
See page 49 of this manual: http://downloadcenter.samsung.com/content/UM/201203/20120322190056420/ST77_English.pdf
The ST76 doesn't have a 1MP setting. The two lowest settings are 1024x768 (0.7MP) and 1920x1080 (2.0MP).
Posted on Nov 25, 2013
Specifications nec fd 1137c
what are you looking for? Here is what I have:
LED Indicator: Green
Interface Connector: 34-pin connector right-angled header connector
Operation Mode Write / Read: 2MB mode / 1.6MB mode / 1MB mode
Disk Used
(90mm / 3.5): High density (2HD) / High density (2HD) / Normal density (2DD)
Data Transfer Rate: 500KBps / 500KBps / 250KBps
Unformatted Data Capacity: 2MB / 1.6MB / 1MB
Rotational Speed: 300rpm / 360rpm / 300rpm
Track Density: 5.3 track/mm (135tpi)
Track to Track Time: 3ms
Required Power: +5V single (4.5V ~ 5.5V)
Signal Output Driver: Open Collector TTL
Input signal Pull-up: 1K Ohm 30%
Function Setting at Delivery: Interface Setting:Pin2: MODE SELECT input (LOW: 1.6MB mode) Pin12: DRIVE SELECT 1 input Pin34: DISK CHANGE Output Other Function Setting: 1. Automatic density setting for 2DD (1MB) disk or 2HD (1.6MB/2MB) disk 2. LED Turn on Condition: DRIVE SELECT 3. Motor Rotating Condition: MOTOR ON 4. Ready and seek-complete gate (full-mask) for INDEX and READ DATA output pulses 5. Auto-chucking at disk installation 6. Auto-recalibration at power on 7. Frame is electrically shorted to DC 0V
Dimensions: 101.6 W X 25.4 H X 145 D mm excluding front bezel
Weight: 345g
Mounting: Vertical/horizontal with spindle motor down
MTBF: 30,000 POH
Safety Standards: UL, CSA, TUV
May 27, 2014 | Teac Computers & Internet
What are the different cpu's that ux915g motherboard will accept? Can it take a pentium D processor?
This would be the Aopen motherboard from the cube...
They take the following CPU's
Processor Number
Processor Frequency
FSB
Ratio
Cache
5 Series
560
3.60GHz
800MHz
18x
1MB L2
550
3.40GHz
800MHz
17x
1MB L2
540
3.20GHz
800MHz
16x
1MB L2
530
3.00GHz
800MHz
15x
1MB L2
520
2.80GHz
800MHz
14x
1MB L2
3 Series
350
3.20GHz
533MHz
24x
256K L2
345
3.06GHz
533MHz
23x
256K L2
340
2.93GHz
533MHz
22x
256K L2
335
2.80GHz
533MHz
21x
256K L2
Note: With CPU changing rapidly, there might be fastest CPU on the market by the you received this installation guide. This table is kindly for your references only.
May 13, 2014 | Computers & Internet
Ms 7529
Hello here are the supported cpu list for your mainboard:
http://www.msi.com/product/mb/G31M3-F-V2--3-Audio-Ports-.html#/?div=CPUSupport
You maybe have to upgrade the bios to support the new cpu.
May 25, 2012 | Intel Motherboard
I would like to be able to change the size of a file e.g. 50% 75% 100% etc
You may want to look into file compression (http://en.wikipedia.org/wiki/Data_compression), but it really depends on what type of file you're trying to "resize."
Just remember that with file compression comes quality loss; for example, if you make a 4MB photo 1MB, the number of pixels per inch will decrease and the photo will end up smaller.
You'll need to be a bit more specific with your question if you're looking for a complete solution.
Feb 24, 2011 | Microsoft Windows XP Professional for PC
My internet speed has been reduced to 1mb from 3 mb since installing this motherboard. My router shows 3.5mb speed and my connection is 100mb duplex. Everything appears OK but the speed will not go above...
use speedtest.com site to verify download is stuck at 1mb
then check the lan settings for the hardware
goto control panel system and check the properties on your lan device
10mb could do this.. maybe
Jan 21, 2011 | ASUS M4A78LTM LE Motherboard
Dell optiplex gx280 OG8310 desearia saber si soporta dual core
dual core not supported but
You can use any of the following processors:
Prescott P4 Kit, 520, 2.8Ghz, 800FSB, 1MB
Prescott P4 64bit Kit, 521, 2.8Ghz, 800FSB, 1MB
Prescott P4 Kit, 530, 3.0Ghz, 800FSB, 1MB
Prescott P4 64bit Kit, 541, 3.2Ghz, 800FSB, 1MB
Prescott P4 Kit, 540, 3.2Ghz, 800FSB, 1MB
Prescott P4 Kit, 550, 3.4Ghz, 800FSB, 1MB
Prescott P4 Kit, 560, 3.6Ghz, 800FSB, 1MB
Prescott P4 Kit, 570, 3.8Ghz, 800FSB, 1MB
Nov 15, 2010 | Computers & Internet
I created a slide show with photos, text and music. The preview looks and sounds great. And the burning to the disk appears to have happened (I can see the ridges in the disc). However, when I go to play...
I have also recently had a problem related to SlideShow Expressions and eventually turned to Individual Software's technical support team for help. I did get help and my problem was solved. You can find them at individualsoftware.com. You have to register your product in order to get help, but it's all free and I recommend it.
However, I'm going to run you through some pointers I've picked up along the way.
Firstly, make sure that your computer meets all the necessary requirements as given on the box and in the User's Guide (included in pdf-format on the install disc). For example, it may be that you have Windows Media Player, but that you need a later version of it. The requirements for SlideShow Expressions involves certain versions of specific media players - these can be downloaded from the web. Also have a look at chapter 3 of the User's Guide (section 3-3) for all the supported file formats (audio, photo's and video). And, yes, DVD+R should work just fine.
Originally, I also suspected my computer (Dell) and my writer drives, but it turned out that the software can sometimes develop difficulties. The following may not apply to your situation, but I'm going to tell you about it anyway, since I believe in the product and I know what it's like to be frustrated making slide shows.
My problem was related to the size of the photos I used and the length of my projects. One can make rather lengthy projects with SlideShow Expressions, which is great, because most other software brands don't allow you to do that. I've successfully burned slide show projects containing up to about 390 photos, using the original sizes (averaging around 300-400 KB, but also including photos of over 1MB and 2MB). (I have a 305 photos large project containing only photos above 1MB each as well, burned successfully.) I hit a problem though with a project of 466 photos in total. It turned out that when moving into this kind of length, the size of your photos needs to be smaller for the software to be able to run correctly. In the end I had to resize all the photos that were over 1MB. I ended up with my largest photo being at 440 KB before I could successfully burn the project. Resizing your photos doesn't necessarily reduce the quality of the photos in your project, though. Really, I can tell no difference between the original sizes and the resized photos in my project. I used Microsoft Office Picture Manager to resize. Also, I was told by Individual Software's technical support team that the option to archive your original photos and music files on the DVD as well, has been linked to burning problems, but this seems to occur mainly when your projects are rather large. I eventually opted for adding a Data CD with the original photos (as an extra) to my slide show project. In this way the project looked great, and the family could copy from the CD containing the original sizes.
Well, maybe some of this will help. I really recommend contacting the technical support people though. Good luck with your project and don't give up - the end result is going to be great. From: 11407336.
Nov 12, 2010 | Individual SlideShow Expressions
Reduce photo size
If you want to take lower resolution photos, it's pretty simple.
Go into the Menu on your camera, and look for "Quality".
Canon does "Large" "Medium" or "Small", if you change to "Small", you'll fit more images on your memory card.
However, "small" will make the photos not look as good as "large", keep that in mind.
Mar 17, 2009 | Canon PowerShot A650 IS Digital Camera
1MB
Greetings Georgejnr,
While there are a variety of programs out there that can be used to resize photos, I prefer to use Paint which came free with my windows on my computer. The procedure I use is the following:
Paint>Image>Stretch/Skew
Then I change the percentage in the horizontal and vertical boxes in the stretch section. Make sure they are the same. It is defaulted at 100% for both, I normally try 75% for each first and you will visably see your image get smaller. When it is at the level that I want, I save it. I chose "save as" and give it a new name, which allows me to retain my original image as well as the resized image. I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
May 07, 2008 | Sony Cybershot DSC-T200 Digital Camera
Change Resolution
Okay this file size is very small and even if you could chage the settings on your camera to the lowest , I'm sure the filesaize will still eb too large.
What to do is use a photo editing program such as adobe or maybe even something else you can get for free. when saving the image you will be able to enter the image size or select what quility, the lower the quality the lower the file size.
To check the file size of an image just right click on it and go down to properties, remember 1mb is equal to 1024kb
Hope this helps
SE0 Consultants - SEO Optimisaton
Dec 03, 2007 | Fuji FinePix A350 Digital Camera
Cameras Logo
22 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
