Question about Kenmore 64663 Microwave Oven
F-9 code in display
My Microwave gives me a F-9 code and stops working !?
  • karilynn Feb 04, 2008
    Microwave displays F9 code and shuts off? Do I need a repair?
  • Kenmore Master
  • 9,174 Answers
F9 usually indicates a problem with the door switches or a broken door switch mount.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your FULL model number here: http://tinyurl.com/gv383
Posted on Oct 12, 2007
6ya staff
SOURCE:
Model 72180883400 Microwave Oven F-9 Failure Code
If the unit is less then 5 years old i believe it is still covered it may be the inverter board or a grounded Magnetron tube. If you need any further assistance let me know. I would contact kenmore directly.
Thanks,
Lee
Sep 01, 2008 | Kenmore 62702 Microwave Oven
My Kenmore Elite over the range microwave model 85293 will only run for a few seconds and then it atuomatically stops and says F-9 on the display pad. It does not heat anything. What does F-9 mean?
Just had this happen - the repair guy says it is the inverter. And they have stopped making the part so it cannot be fixed!!! When did you buy your unit?
Jul 03, 2010 | Microwave Ovens
F-9 pops up - microwave stops after 5 seconds. This is a Kenmore Elite Microwave, made in 2003. Model 721 63683300
Hello :
The F-9 error code indicates a defective control board, inverter or line voltage too high .
WARNING : A microwave is capable to give you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
good luck .
please don't forget to rate !
Apr 04, 2010 | Kenmore Microwave Ovens
Model 72180883400
F-9 error code indicates a defective control board, inverter or line voltage too high. f the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
Microwave won't run
F9 code means either a bad door switch or a loose door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(If not, please reply back with your brand and model number so we can help you.)
Aug 03, 2008 | Microwave Ovens
GH7208XR Error Code #7
Behind the right front corner faceplate is a bag with the tech support info.
I used this and went through all the troubleshooting and got to the power inverter board. This board has the 2 red wires out of it that go to the magnetron. Instead of replacing the whole inverter module , I examined all the components on it. I found that there are 2 high voltage rectifier diodes attached to the transformer and 1 of them was not testing good. The diodes are UXC2B diodes.. Just clipped out the bad one and soldered in a new one.
Hope this helps..
Dec 21, 2007 | Whirlpool GH7208XR Convection / Microwave...
F-9
Need to know the entire model # on the microwave.
Oct 05, 2007 | Microwave Ovens
Kenmore 64663 Microwave Oven Logo
83 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
