Question about Fujitsu Computers & Internet
How can i activate my webcam fujitsu lifebook SH760
  • 159 Answers
SOURCE: I HAVE A PROBLEM W/ MY FUJITSU LIFEBOOK FMV 6866NU
You can download new drivers from here:
http://www.falconfly.de/voodoo2.htm
That's a spectacularly old laptop, fyi. The video card manufacturer went out of business a decade ago.
Posted on Dec 07, 2008
Geekman
  • 32281 Answers
SOURCE: Fujitsu Lifebook C4135 specs (32bit CardBus slot included?)
This is a very old laptop, when new it was installed with Windows 98.
Not sure if it had a PCMCIA slot on the laptop, but it can be easily identified if you look on the laptop. If it has PCMCIA slots, most likely it would be located on the LHS or RHS of the laptop. The PCMCIA could be a single slot or a double slot and it would be 55mm wide ie 2 3/4 inches wide with an eject button for a single slot and two eject buttons for a double slot.
Posted on Jul 06, 2009
  • 59 Answers
SOURCE: touchpad stopped working on my Fujitsu lifebook
You need to re-enable it. Hold Fn and hit the F5 or whatever key is appropriately assigned to the touchpad. This should enable it for you.
Posted on Oct 19, 2009
joecoolvette
  • 5660 Answers
SOURCE: I am looking for an Instruction Book for a Fujitsu Lifebook Laptop computor
User Guide for the Fujitsu Lifebook T4010,
http://www.pc-ap.fujitsu.com/support/manual_lb.html
Go to the right column heading - T Series.
Left-click on - T4010 - below.
[ This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (T4010), it may take up to 30 seconds before the first page comes up.
The PDF file may be shown in the newer PDF file format.
To go back to the older format, hover your mouse cursor towards the Bottom/Middle.
Left-click on the Adobe PDF icon (Red) all the way to the right ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 28, 2012
SOURCE: Replacement of Fujitsu Lifebook N6420 cooling fan
Note this procedure is specific to the N6420, but may work on other N series Fujitsu notebooks. I generated this solution by a step-by-step process on my N6420.
Procedure for replacing (two) cooling fans on Fujitsu Lifebook N6420. This procedure was required because of fan bearing noise, indicating potential failure of the fan in the future and the noise was very annoying. I performed this procedure after about a year of bearing noise and after not finding any reliable procedure on the web. Fujitsu offered to replace the fans for $230 - far more than the laptop is worth at this point. Below is the correct procedure for the N6420 and specific to that machine.
You will need to purchase two cooling fans Toshiba Part Number S6055AM05. Be sure and purchase the ones with metal backing on one side of the fan. You can find them on eBay for about $10, but beware of what you buy. Recommend you purchase new OEM fans and not refurbished fans as they may not come with the thin metal heat transfer plate provided on the OEM fans. Some of the knock-off and refurbished fans do not include the metal backing, heat transfer shield. You will not need thermal paste.
Note: All of the other instructions on the web I found for the N6420 were incorrect and seemed to be lifted off some other notebook. I actually performed these instructions and made sure they are accurate.
Note: While you wait for the new fans .... and you must use your N6420, but want to buy yourself a little time before the fan(s) totally die ... you can try this procedure at your own risk ... and spray a very small amount of silicone lubricant between the fan electronics and the spindle - this area is easy to indentify if you hold one of the fans on its edge. The use high pressure air spray to blow out any grit, dust and silicone overspray - wipe each fan with a clean cloth. This little bit of lubrication and cleaning made the bearing noise go away. Both fans are spinning up ... but, I ordered new fans anyway to make sure the notebook would have adequate cooling and to preclude the old fans from going bad and causing catastrophic overheating.
Here is the fan R&R procedure itself:
- Shut off the notebook and disconnect all peripherals
- Remove cover to RAM (optional)
- Remove Battery
- Remove HD Cover and HD(s) (I have two - some may only have one)
- Remove 15 retaining screws
- CAREFULLY - Remove base/bottom notebook cover, take care on the side with the PCMCIA slot, USB port and sound ports
- Note orientation of the two fans so you can replace them the same way
- Now remove the two old fans (two screws)
- Install the two new fans
- Replace two screws under HDs
- Replace two screws under battery
- Reinstall the base cover - take care on the side with the PCMCIA slot, USB port and sound ports
- Replace the remaining base cover retaining screws
- Replace HD cover and its retaining screws
- Replace RAM Cover
- Make sure you have no/zero retaining screws left (all 15 screws and the HD cover screw are identical)
- Restart Notebook and get back to business
Posted on May 14, 2012
Testimonial: "I had to log in as my better half to generate this correct procedure. This is the step-by-step procedure for replacing the fans on a Fujitsu N6420. There is no need to take the keyboard out and no requirement for thermal paste. This procedure is far easier than it appears to be and is specific to the N6420."
How to activate touchpad on fujitsu lifebook modela6025 a series
Go the Device Manager under Control Panel and make sure it is not disabled. Right click and select enable. If you see a yellow exclamation mark next to it means the driver has not been installed and you will have to download and install it.
Jul 17, 2014 | Fujitsu LifeBook A6025 Notebook
Fujitsu lh530 webcam driver not found
From Fujitsu:
Any webcam s.w included with your machine will be provided on your Drivers & Utilities DVD (DUDVD)
If you browse/explore it look for a SOFTWARE folder , when in the folder look down the list you may have something called cyberlink youcam. Double click to install.
Terry
Mar 30, 2014 | Fujitsu Lh531 Lifebook 14 Hd...
LIFEBOOK AH531 webcam not working
I don't know what program you are trying to use. Does it work on skype? Or a similar program. I would suggest using a free service to test the webcam.
Nov 12, 2012 | Fujitsu LifeBook AH531
Webcam of my fujitsu ah 530 notebook does not working, pls help.
Dear user please reinstall your webcam driver and your problem will be solved ...............try it
Jul 07, 2011 | Fujitsu LifeBook AH530 NoteBook
How to invert the upside down showing webcam of siemen?
Check the WEcam settings. Most WEBcam have a setting toinvert and mirror the image
Apr 08, 2011 | Fujitsu Siemens Fujitsu Lifebook P7230...
My Lifebook P7230 camera is upside down .
I had the same problem, even after updating drivers, but I found solution.
1. Go to website:
http://www.pc-ap.fujitsu.com/support/drv_lb_vista_p7230.html
2. Download file: Camera Driver (for model with Fujitsu WebCam module) V.1.0.0.1088b
3. Unzip it
4. Open "fujitsu_webcam" folder
5. Run "Setup" and follow instruction
6. When installation is finished restart computer can be required.
7. Next, go to START, and open WebCam in Camera. Check settings. Now, everything should be OK.
Enjoy :)
Apr 02, 2011 | Fujitsu Siemens Fujitsu Lifebook P7230...
I need a driver for my fmv lifeebook
1st You download Webcam Driver. Fujitsu LifeBook Cam Driver After this install the Webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
May 02, 2010 | Fujitsu LIFEBOOK FMV-U8240 Tablet PC
Computers & Internet Logo
29 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
