I am working on unitronics plc with enfora 1308 modem.My project work is about to transmitt data over static ip in eathernet to opc server.But i ,neither connect modem with hyper terminal nor regigter the gsm ntwk of vodafones give me instrucion wise sollution plzzzzz?:-)
  • viral jani
    viral jani Nov 25, 2013
    There was norespond in hyper terminal with ideal configuration
SOURCE: 192.168.1.1 unreachable
you can use the "ifconfig -a" to see the ip addresses of all network adapters. but i'm wondering what happened to the user interface that showed a list of options to choose from.
Posted on Mar 16, 2008
SOURCE: Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
do you know how to network a 7420 fax ?
Posted on Jul 11, 2008
SOURCE: dialup 56k modem not responding.help says harware failure
whts the name of the modem and the light status and , whts the error message u get when u try to connect to the internet
Posted on Nov 15, 2008
  • 14 Answers
SOURCE: Can't open port to uTorrent
virtual server also known as port forward, try to look for this phrase, if not u may also find some word with NAT or Nat table.
Anyway routers must have this function in general.
By the way, how did you make your ip static, manual from your mac or the routers'?
Posted on Nov 25, 2008
SOURCE: Cant change or remove the password.
with some system you will have to use ctlr H before the password system
this removes the space so the password is correct
Posted on Nov 29, 2008
I have 2 different magnia sg20 servers. One is in the office and the other one at home. Now I want to access one server from the other network. But as both of them have the same ip, I am blocked. So I...
No. You are on two different networks. Regardless of the hardware. Treat the home server just like any other PC or tablet. Make sure it has a dynamic IP via DHCP from your home router or ISP modem. Then connect via VPN.
You will not be able to network the two servers unless you have right equipment and network configuration. You would have to work with your service provider to obtain static IP's.
Internal IPs are irrelevant, because you can assign them your self internally. That means no one else sees them.
Mar 08, 2013 | Toshiba Magnia SG20 Server
I installed Leadtek USB modem on W2K. It operates sends data but does not receive data. I dont get the IP address. What to do?
check your gateway working fine or not
do u have dynamic ip or static ip if u have any fix ip so fix in the network property proper way check your dns if the recived dara not up so complaint your ISP
Sep 23, 2011 | Computers & Internet
Newbie to servers, ive been given an computer with server 2003 loaded on it it has been through the first stage setup and now im with a few things, mainly when i run the email and internet connection...
DNS-servers translate names, such as 'www.fixya.com' to IP-addresses, because routing of IP-packets on the Internet is done using the IP-addresses, not by using the names of each computer.
If you have a router between your computers and your cable-modem (or DSL-modem), then the router can automatically supply the "Primary DNS Server" and "Secondary DNS Server" and "IP Address" to your server computer, if you configure the network-adapter on the server to "automatically obtain an IP Address".
As long as you leave your server running, the "dynamic" IP-address that it obtains will, in effect, become a "static" (namely "non-changing") IP-address.
Feb 03, 2011 | Computers & Internet
Plycom ip330 phone - works fine when connected directly to Brighthouse modem, however when brighthouse modem connected to belkin router then to phone says - waiting for network to initialize, please help
sounds like your belkin router is not setup as a DHCP server or the DHCP is disabled. The DHCP in the belkin assigns addresses to the internal network, the error "waiting for network to initialize" means that the phone is waiting for an IP address, to which its not getting. When you connect directly to your modem you get an IP from your Internet service provider. I'll bet your internal network is setup using "static" ip addresses, if thats the case you will need to surf into the phones web console and set a static IP address. Or the opposite, enable DHCP in the belkin. hope that clarifies things a little.
Aug 28, 2010 | Polycom SoundPoint 330 IP Phone
I have a 2wire modem from att. i made a 50 foot eathernet cord, i have a eathernet transmitter teaster to test the cable to see if it is good (and it is) but i still cant get internet on the other side of...
Try with a shorter enet cable and see if you get internet, if you are able to get internet with a shorter cable then the cable might not be working fine. Else get a wireless card installed on your computer since the 2wire modem has wireless connectivity. It would be more easy and convenient to connect to wireless using the 2 wire modem.
Jun 24, 2010 | 2wire (1000-000057-000) Modem
First of all sorry for my english i have 10 user pc and 1 server (windows 2000 sp4) and 1 modem i have static ip address in my modem and i give the local ip in my modem 192.168.0.2.......ok i give the...
Each of the eleven(!) computers needs:
1. a _unique_ IP-address
2. the IP-address of the "gateway" device
3. the "network-mask" (usually 255.255.255.0)
The IP-address for your server must *NOT* match the IP-address of any of the 10 computers.
The IP-address for your server must *NOT* match the IP-address of the "gateway" computerl.
Nov 13, 2009 | Microsoft Windows 2000 Server
Nov 23, 2008 | Computers & Internet
Static Ip with Speedstream 4200 Modem
I am assuming here with the way you have it set up your getting an internet connection.
what you saying i understsand mostly so i'll see if i can help you
first of all you have speedstreem modem that connects to you isp, this is assign your internet address from the isp if you paid for a static IP it would be in here, if not it's assiged by a dhcp from your isp company so if you if turn it off or have a power loss for anymore than 5-15min your ip changes.
now your modem then connects into your belkin router this as well as your modem it's prob set up as dhcp so it wants to issue each computer with an internal address of 192.168.0.X the reason for this is so it knows where to send the incomming information to what computer.
no matter what computer your using the address that goes over the internet will be the one assigned to modem from internet provider so if this need to be static IP to run your game server you will have contact your internet provider for an address.
but you may be confussing the issue a little, my suggestion to you would be:
1. go to your connections on each computer
2. right click on the lan connection choose properties
3. go to internet protocol (TCP/IP) then click properties
4. then click on obtain ip automatically and obtain dns automatically
this will remove the static windows address you may have put in.
try this and see if you can get you game or game server will work.
btw you may have to reboot your computers after this to get be sure to get the new address.
Oct 09, 2008 | Siemens SpeedStream 4200 (13A4200001)...
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Feb 25, 2008 | RCA Cable Modem DCM315R (11603540)
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
