Question about Empire DV-55 Heater
Fano loud on FAW-40-1SPP
Fan is loud on blower
Faw 55 no fan operation
All fan switches should read open line or "OL" when the furnace is cool, but if the motor seems stiff see if it is oilable. It may have small holes covered by yellow or black plastic plugs covering the holes. If it does and you have not oiled it, go to the hardware store and ask for a motor oiler such as a Zoom spout. Place 3-5 drops of oil in each hole then spin the motor by hand, it may loosen up. The limit side of the fan/limit switch has no impact on the fan motor.
Feb 01, 2015 | Empire Comfort Systems EMP FAW-55-SPP-1N -...
The engine fan blower is loud while accelerating in 2006 chevy trailblazer
sometimes it takes a few seconds for the fan clutch to release, as long as it quiets down don't worry about it.
Jul 19, 2014 | Spyder 2006 2009 Chevy Trailblazer Lt Mesh...
Ac fan is making extremely loud noises
Are you referring to the blower motor inside the car? If so, they get leaves in them which puts them out of balance and makes them noisy. Just take out the blower, 3 screws, and clean it. That's the cheap answer. It can be a bad blower motor.
Jul 07, 2014 | 1999 Honda Civic
Goodman ac clj142 A loud screeching from the inside unit. Sounds like a belt? Turns on, cools and get loud and shuts off.
No belt direct drive.most likely bad motor or blower wheel separated or loose.if not blower will likely need motor
Jun 01, 2014 | Heating & Cooling
Very loud when fan is running
This is likely caused by a faulty blower motor bearings, or the fan has something in it or it could possibly have broken. Shut down power to unit, remove cover and inspect the fan shaft, blades, and spin it. it should freely spin. If it hangs up you likely have a bad blower motor.
Mar 03, 2014 | Carrier XHB123D X/Y Series Heat/Cool Air...
Loud blower on my Coleman Furnace
Usually a noisy blower motor is a bad bearing. The motors now have oil impregnated bearings and you can't oil them, you have to replace them.
Sep 19, 2012 | Coleman Mobile Modular Home Electric...
It is very loud inside when turned on. the noise sounds like a loud rumbleling noise.
Is this a window unit, a whole house AC, or a Split package type?
If it is a window unit remove the front cover, reach in and see if the blower fan teeters on the mother shaft. If it does the blower fan center hub has failed and the fan will need replaced. (I have changed 2 blower fans on my Carrier 19,800BTU window units that run 23 hours a day.) They just fail over time. Who knows why.
Kelly
Feb 23, 2010 | Heating & Cooling
FAN BLOWER VERY LOUD ON HIGH
HI!!! open the fan conpartment pull the fan out and see how it works maybe wobless when spin the bearing from the fan worn out o something is inside the.fan compartment?????
Feb 26, 2009 | 2000 Toyota Camry
Offline park eject error
The problem comming from FAW sensor , adjust the FAW sensor. Check gears ,if it broken change it.
Feb 14, 2007 | Tally T2245 Matrix Printer
Heating & Cooling Logo
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
