Question about Motorola Walkie Talkie 2-Way Radio
When i press key to call i heard do do do
Model motorola 5118
  • Motorola Master
  • 1,654 Answers
If it is three beeps, this is could be a sign of a bad or poorly charged battery. The first thing to fail is generally transmit. It takes more energy from the battery to transmit than to simply receive or be on standby.
Swap your battery pack with a known good battery pack from another unit and see if the problem is solved. IClean your battery contacts with a pencil eraser, and replace batteries as needed.
Best regards.
Posted on Nov 27, 2013
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
My vivitar camera 5118 wont charge
It's because the 5118 is a camera, not a battery charger. It uses disposable alkalines or rechargeable NiMHs, but if you choose to use rechargeables then you much charge them outside the camera using a separate battery charger.
Apr 12, 2013 | Vivitar Cameras
Why my vivitar camera 5118 wont charge
This is because the 5118 is a camera, not a battery charger. It uses disposable alkalines or rechargeable NiMHs, but if you choose to use rechargeables then you much charge them outside the camera using a separate battery charger.
Apr 12, 2013 | Cameras
How long does it take for a vivitar Vivicam 5118 to charge fully?
Since the ViviCam 5118 isn't a battery charger, it will take a very, very long time.
The 5118 uses standard AA batteries. If you want to use rechargeable batteries then you much charge them outside the camera using a separate battery charger. Connecting it to a computer through the USB port will drain the batteries even faster, since the camera has to expend power communicating with the camera (even if only to say it has nothing to say).
May 08, 2012 | Vivitar ViviCam 5118 Digital Camera Blue...
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
I have a motorola i580 cell phone that has an eight code number, which the phone is in subsidary lock and I would like to have the code to unlock the phone
here are the full motorola list of codes unlock code is included enjoy.
Code Action
*7 Use to lock/unlock the mobile keys
19980722 Work as "Master key" to unlock the Motorola sets
*#06# To display the IMEI Number of the mobile
*#403# Press keys to get information about mobile manufacturing
*#301# Use to test the functions of the keys
*#303# Use to reset default language to English
*#300# Use to display the mobile software/hardware version
*#311 Use to reset the default code of mobile
*#402# Use to regulate the mobile display strength/intensity
*#304# Press keys to OFF the engineering mode
*#304*19980722# Press keys to ON the engineering mode
*#0000# Use to reset Motorola mobile default language
1234 Default Motorola mobile code
32*279*1*0*8 Use to verify the mobile model
#PROGRAM# Use to change the default banner of mobile
##33284 Use to run mobile in Debug mode
#02#* Use to display the mobile software version
*#42253646633#
Use to enable COM port
*#987*99#
Use to restore the Motorola factory settings
#32# Reset the mobile timers
###119#1# Use to make active the EFR mode for mobile
###119#0# Use to make deactivate the EFR mode for mobile
Nov 12, 2009 | Motorola Mobility i580 Cellular Phone
How to unlock a motorola cellphone that comes from venezuela.How can I unlock it so it would work here?
yes.... there is free unlock code for your Motorola L6.... i am a usertoo of Motorola L6 and i juz figured out how i can get the unlock codefor my Motorola L6.... you can do it all by youself!!!! juz follow this:
1)form your Motorola L6 idle mode, press d menu key (menu key is d keybetween the left and right soft keys) and go to Settings>Security> New Passwords> then change unlock code;
2) as you sEe, Ur phone is asking for Ur old unlock code, press the menu key to switch it to security code;
3)as U press the menu key, U will notice that Ur phone is now asking forUr Security code.... enter Ur security code (the default Security codefor Ur Motorola L6 is six zeros<e.g. 000000>) then press<OK>
4) now, Ur phone is asking for New Unlock Code, type d code U want (max. of 4 chars.) then press <OK>
5) enter again d Unlock code for verification....
TIP:if U forgot Ur Unlock code again, juz do d process again. u canforget Ur unlock code but never forget Ur security code!!!! you canswitch the unlock code into security code by pressing the menu key!!!!
is that thing solve Ur problem???? pay me back by sending me Ur coMment: phreanz_44@yahoo.com
this solution is for Motorola L6.... try this to Ur Motorola phone and see if this work!!!!
Sep 30, 2009 | Motorola Mobility L6 Cellular Phone
My phone is set in Italian. How do I change the
My phone is set in Italian. How do I change the language to English?
Jul 06, 2009 | Cell Phones
Radio Communications Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
