Hotpoint aquarius ctd00
Hello, I have had my tumble dryer for approx. 6 years now and from around 6 months old it has started to make a noise when in a reverse spin. It has gradually got worse and it is now at a point it is just horrendous. It has no other problems, it gets cleaned out regularly etc and still heats up perfectly. I have noticed it is starting to take longer for loads to dry. Any suggestions or help please?
    Scholar:
  • 171 Answers
The noise could be .... the drum sometimes has stick on metal pads for balance or heat shields that will come up and start smacking on the cabinet of the dryer. Remove or lift the top of the dryer and turn the drum and looks for these pads. if one has lifted either glue it back or cut the part off that has lifted.
As far as the not drying part ..... it could be that the dryer is just getting tired and the heating element is gong bad or it could be something as simple as cleaning out the vent going out of the house. You can do this by disconnecting the dryer from the wall and blowing it out with a leaf blower or having someone come in and do it professionally.
Hope this helps.
Posted on Nov 25, 2013
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Tumble dryer not heating/drying
To check the element and stats, you need to remove the rear panel of the dryer, there you will see the stats and the element, you need to check for contin uity with a meter set on the ohms range, do it with the stats disconnected, or you will get a false reading.. if one of the stats has gone, then you must replace both of them.
Check thst all filters are clean ,air intake and outlet clear, and wash the lower fluff filter out under a running water supply.
If still no joy ,then could be a control unit prob..
Plz rate my solution
Thanks.
Posted on Dec 29, 2008
apart4u
  • 213 Answers
SOURCE: I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Posted on Jan 10, 2010
  • 195 Answers
SOURCE: my hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
HI. CHECK YOUR BELT FIRST.IF GONE CHECK DRUM BEARINGS.TOO.THIS COULD BE THE REASON FOR THE BELT TO GO.GOOD LUCK.ALI
Posted on Jun 26, 2012
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius ctd00 tumble dryer...everything working but drum wont turn
it looks like you need to put the belt back on which is inside the machine. to do this open the lid with screws on back take lid off then you should see the belt inside the machine and where is was before on the drum of the machine. slip it back on and put lid back on and it should start turning again. hope this helps.
Sep 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Dryer revolves but no heat on any settings . hotpoint aquarius tumble dryer CTD00 7Kg.
fixed using posted advice on resetting thermostat.
Many thanks
Dec 10, 2009 | Hotpoint Dryers
Hotpoint aquarius ctd00 condensor dryer drum not turning in reverse direction, belt seems to be ok
The reversing tumble action is controllerd by the timer, so it could be contacts in timer.
It is useable running in one direction.
Check for loose or broken wires to motor as well.
Hope this is off some help to you.
Dec 07, 2009 | Hotpoint Dryers
Hotpoint tumble dryer CTD00 timer
It is not a difficult job...the thing to keep you out of trouble is to make sure you get the right timer switch, then remove one wire at a time.
Remove one wire from the old timer and put it on the new timer, there is not that many wires for your timer.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 05, 2009 | Hotpoint Dryers
Tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Washing Machines Logo
Top Washing Machines Experts
