Coleman electric Furnace won't come on seems not to receive input from thermostat
Power surge during lightening storm this summer knocked out my thermostat. Installed new one but furnace won't come on.
    Genius:
  • 1,198 Answers
There probably is a little transformer that runs the thermostat, at the furnace. If it is separate, it is easy to replace.
Posted on Nov 26, 2013
  • 92 Answers
SOURCE: Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Posted on Feb 05, 2009
  • 56 Answers
SOURCE: ruud achiever 90 plus won`t start
Check the data information on the unit there should be a troubleshooting guide that tells you what the two lights blinking once means. hope this helps.good luck. normally found with schematic
Posted on Feb 12, 2009
farfield
  • 462 Answers
SOURCE: Sometimes the furnace doesn't come on when it should
OK so its an all electric furnace no gas? I cant think of anything clicking on an electric furnace except the sequencers or the safety switches.
If this is whats your hearing then the fan should definitely be running.
Feel carefully around the fan motor (I assume this is in a mobile home). See if you detect any heat coming around the blower area close to the fan motor. If so the fan motor may be at fault or one sequencer may be out (the main one of course...) the thing is can you get the fan to come on by turning the auto switch on the thermostat (or if older model the Auto On switch on the furnace) to ON? If so you can "limp by and have heat til someone either checks it or you can go on deeper into it. but to go deeper you'll have to let me know you know where the elements are and that you have a volt meter. and feel comfortable using it especially on HOT wires.
Posted on Mar 04, 2009
  • 233 Answers
SOURCE: need a downloadable pdf electrical
http://www.colemanac.com/PDFFiles/036-31114-001-C-0109.pdf
Posted on Jul 15, 2009
flatech
  • 111 Answers
SOURCE: bryant programmable thermostat will switch on furnace
Turn the power off to the Air handler unit.
Remove the thermostat from the wall, (Just the face part).
Look on the back side of the thermostat and verify that the jumpers are set to electric and not gas, otherwise the fan will not run during heat mode, they come from the factory usually set for gas.
If this is a electric heater this will solve your problem, If it is gas then it will be more detailed. Once you put it back on keep in mind that most thermostats have a 3-5 minute delay so just give it a little time and the fan should then work once you have the jumpers in the correct position.
FlaTech
Thank you for using FixYa!
Posted on Nov 17, 2009
My HDTV went out in a lightening storm. What could it be?
Is your TV plugged into a surge protector? If not it very well may have gotten a power surge during the lightening storm that fried components in the TV.
Or is the TV connected to a cable box? It could be that the cable box took the hit if it's not plugged into a surge protector.
Or a possibility of both.
Aug 03, 2015 | Proscan Televison & Video
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
RE: Aquos LC40C32U. I replaced the power supply bd a year ago, cost $110. It has failed again (no power light.) ater a series of lightening storms. I am reluctant to spend more money on it. What is...
You can't blame any component in the TV failing after lightening storms. Get lightening arrestors on the antenna cable and use a surge protector on the power cord before you replace the power board again.
Sep 02, 2011 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Will not heat we replaced both elements but still no hot water rheem model no.82v522marlene we suspect we had a power surge during last storm because the furnace went out also at the same time
Hi I suspect your thermostat will have also been damaged if you had a surge I always replace thermostats at the same time as the elements
Also check the wiring as sometimes surges can melt the copper core of the wiring, but be careful always turn off the power first before any electrical works!
Mar 06, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Hi, my problem with tv emerson plasma 42 etv4206pdp it does not turn on, after rainy and lighting day. i check the main power area and cant find anything grong. i dont know what else to do. if you had a...
It might have been blown out by the lightening storm. that happened to two of my tvs that were plugged in during a lightening storm. they both, and two dvd players, would not work after, but the ones that were not plugged in were fine. You should unplug your major electronic equipment during a storm, unless you have a power surge plug/equipment.
Oct 04, 2009 | Emerson EWL3706 37 in. LCD Television
Fan blades not turning
First check all the breakers. Locate the breakers to the outdoor unit, turn them off, then back on. If that is not the problem, you likely have a capacitor blown to to power surge, or static charge from a close lightening strike.
Aug 30, 2009 | Honeywell ER150B Air Conditioner
No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Jul 15, 2009 | Samsung LE32A457 32 in. LCD TV
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
