Question about Kenmore Dryers
I have a kenmore 80 series electric clothes dryer that will not heat. i am needing to know which part is the heating element, and describe what it looks like
    President:
  • 1,136 Answers
Hi, The element is located in the back right side on most models. It is in a housing and has two red wires going to it. Also check the thermo stats if the element is ok.
Posted on May 08, 2009
  • 351 Answers
Get to the back of the machine. Unplug and remove dryer vent. take the 9-11 quater inch screws out there you will see all the goodies on the right is the element i recommend takeing continuity or connecting the wires on the thermal fuse directly above that. try to run it. if that does not work then check for 220 at heating element. if you have electricity then its the heating elment. i have them on sale at www.whirlpoolpartssurplus.com
My gas kenmore 80 series is not heating?
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
May 20, 2014 | Kenmore 80 Series Heating Element -...
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
My Kenmore 80 Series dryer is no longer heating up? What part needs to be replaced??
Gas or Electric? If Gas it could be the gas valve isn't opening, this keeps the burner from lighting. If electric your heating element is most likely burned out.
Aug 03, 2010 | Kenmore 84052 Dryer
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 24, 2017 | Kenmore Dryers
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore Series 70 Dryer
I'm not familiar with your dryer model but general advice regarding dryers with the problem that you have described would be to ensure that any filter on the outlet is clean, whether it be a condenser or traditional external vent.
Ensure, if it is vented rather than condensing (only connected to a drain) that the vent tube has clear access to expel the damp air circulated during the drying process.
If the wash load is heating to a substantial temperature in the dryer, it isn't the element causing the problem.
May 07, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
the heat thermostat are not functioning well/need to replace parts.
Dec 31, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
197 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
