Question about Indesit Washing Machines
Indesit witp 102 - the engine is not starting - a click sound can be heard every time it tries to spin. if i use a hair dryer to warm the engine and the parts inside it starts and works fine :) can this be fixed somehow?
    Genius:
  • 1,198 Answers
Check the capacitor, but be careful, they store a good charge, like a tazer! Once removed and safely discharged, check it for damage and function. A dent will ruin it.
One check is to connect an ohm meter to the tabs, the needle should swing over and come back. Reverse the leads and do it again, the needle should swing again. If so, it's usually good.
Also check the motor bearings. With the belt off, the pulley should not be able to move side to side, and the motor should spin freely and quietly.
Posted on Nov 26, 2013
  • 641 Answers
SOURCE: dial clicks round
Open the rear panel and look for a broken or worn belt. If this is the problem you can replace it easily. Good luck !
Posted on Jun 16, 2006
SOURCE: Indesit W123s
There is a bearing at the back of the machine that normally goes.don't just replace the bearing.buy a complete bearing kit and replace that.
Posted on Feb 28, 2007
  • 1294 Answers
SOURCE: indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Posted on Jun 16, 2007
  • 15 Answers
SOURCE: indesit machine won't start
on the bottom of the machine there is a panel made of plastic that may be removed to expose the waste filter.open the waste filter and check that the waste pump is not blocked as in the initial start up the pump is run if there is a problem with the pump the machine will not advance.
Posted on Jul 19, 2007
  • 2920 Answers
SOURCE: maytag neptune smoking
it could be the seal on the drum or it could be the belt getting too warm
Posted on Jan 12, 2009
Need the Indesit WITP 1021 washing machine manual
Try Googling (indesit)(WITP 1021)(manual) without parens.
Jun 20, 2017 | Indesit Washing Machines
Opel meriva problems
ecu temp sensor has failed. easy to test this with a hair dryer take the cover off on a cold day try to start engine if not warm up the ecu with the hair dryer. then try to start the engine if its starts then the sensor on the board inside is failing.
Sep 29, 2013 | 2007 Opel Meriva 1.8
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Indesit Widl 102 Flashing lights, wont turn on
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and/or its panel that is going bad. To start with check the Thermal fuse which is mounted to the exhaust duct inside the back cover panel. Please do accept the solution if the issue is resolved or post a comment with a more detailed question including the manufacturers name and model no# for your dryer so that I can further assist you.
Thanks
Rylee
Jun 14, 2010 | Indesit Dryers
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
2005 hyundai accent wont start
try this? remove all spark plugs and dry them out use a heat source ie gas hob? if wife permits?? then spin engine over to clear cyl/s and refit warmed up plugs ? if you have wd40 or ignition damp start? spray all ign coils/leads electrical connections/ or see if wife will let you use hair dryer and carefully blow ign leads/coils etc then try restart ? this may be a simple case of damp plugs/ignition and engine/plugs are flooded from dampness trying to start after snow ? wish you luck please update on progress
Dec 31, 2008 | 2000 Hyundai Accent
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Indesit dryer
hi there sounds like the start relay is faulty this can be located behind the control panel or as part of the door interlock depending on what model she has.
May 02, 2008 | Dryers
Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
Feb 07, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
