Question about YouTube Videos
Reset my tire pressure light in my 2006 infinity QX56
I just replced all my tire prssure sensors. they are brand nes. I need to reset them to get rid of the sensor light on the dash board
    New Friend:
  • 4 Answers
Probably not the best way, but disconnect the negative ( - ) battery cable and push on the brake pedal a few times to fully discharge the system. However, doing this all your radio settings will be reset as well as you having to reset any digital clocks. This is a quick and dirty way to reset the lights.
Posted on Nov 25, 2013
How to reset tire light
could have a bad sensor
Apr 12, 2014 | 2006 Infiniti G35
How do i get the low tire pressure light off from a 2006 infiniti g35x
Have sensors checked at each wheel to make sure they are working, a tire shop should be able to do this for you. The spare tire may have a sensor so be sure to have that checked. If this fails then a problem in the main computer is possible
Apr 02, 2014 | 2006 to 2007 Infiniti G35X Tire Pressure...
The tpms light in my infiniti g35 is on. I already check the tire pressure and they are fine. Do i have to take it to the dealer or can i change the sensor my self? Appreciate your answers thank you
tire pressure must math that on the drivers door sticker, other wise it will not reset. After you set the proper pressure you must drive the vehicle for several minutes above 25 miles/hr to activate the TPMS and turn off the low tire pressure warning light, If you have the sensor replaced you have to take it to the dealer or a discount tire shop to have it activated to your vehicle
Nov 06, 2013 | 2005 Infiniti G35
What does a triangle with an exclamation point mean?
TPMS-Tire pressure monitor sensor. low tire or bad sensor. if your tires are more than 3-5 pounds under pressure, this will trigger the light. Check your driver door for proper tire pressure, air the tires up and drive for 15 mins. If light doesnt go out, check the owners manual for reset procedure.
Jan 27, 2011 | Infiniti QX56 Cars & Trucks
After inflating my tire to specs my tire sensor will not erase from my dashboard on my infiniti fx45. is there some way to get it off via turning key pushing brake pedal type thing???
Please verify spare tire pressure as well. This colder weather has probably lowered the pressure in that one as well. Manufacturers have been including pressure sensors in the spare tires, as well as your regular tires. for a few years now.
Dec 14, 2010 | 2006 Infiniti FX45
VDC SWITCH AND SLIP LIGHT ON qx56 2006
My VDC switch and slip light is on in my qx56 2006. what can I do to get it off?
Aug 31, 2010 | 2006 Infiniti QX56
Flashing exclamation point
definetly tire prssure low light. you can reset it by scrolling through the mileage and trip meter once you get to the screen for the tire preesure monitor hold the button down till it flashes and it will reset. make sure you check all your tire pressures first.
Aug 07, 2010 | 2004 Ford Freestar
Tire pressure light is on
You cannot reset them,Make sure that you check the pressures in the tires. The Infiniti Tire Pressure Monitoring System is designed to trip the warning light anytime the pressure in any of the tires drops below 29 psi. At 29 psi it really won't look like the tires are low. You could have one tire at 29 or 28 causing the light to stay on all the time. Check your pressures, set at 34 or 35 to be safe, or whatever pressure the tire is recommended to be. Not all infiniti vehicles with TPMS have the display that shows the pressure in each tire. If the pressures are above 29 psi, Then there could be an issue with one or more of the sensors. If you have the tires replaced you will have to have the sensors relearned at the dealer. Tire rotations do not require the same.
May 02, 2009 | 2005 Infiniti G35
Reset indicator lights
The " Check Engine" pertains to the computer sysytem informing you of a failure code stored. In order to clear , the problem must first be solved, and then clear the computer. Tire prssure warning light advises of low air pressure in any of your tires. Check tire pressures. A fault in a particular tire valve sensor may also indicate a fault if all pressure are up to spec
Apr 04, 2009 | 2003 Chevrolet Monte Carlo
YouTube Videos Logo
78 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
