Question about YouTube Videos
Reset tire pressure sensor on my 2006 Infinity QX56
    Renaissance:
    An user who is expert in 3 categories / brands.
  • YouTube Master
  • 825 Answers
Update your browser
Posted on Nov 25, 2013
Reset my tire pressure light in my 2006 infinity QX56
Probably not the best way, but disconnect the negative ( - ) battery cable and push on the brake pedal a few times to fully discharge the system. However, doing this all your radio settings will be reset as well as you having to reset any digital clocks. This is a quick and dirty way to reset the lights.
Nov 25, 2013 | YouTube Videos
Qx56 will not play any cd
Put in a CD that is fairly new that you have not recorded and see how it plays. If a new CD plays well then it is possible that there is an issue with either the CD itself or the head within the CD may be out of alignment. If all else fails then take it to a reputable audio installation facility or the Infinity dealership in your area. Depending upon how you feel about your Infinity, you could do well with a third party CD player. Are you having any other audio problems?
Apr 02, 2012 | 2006 Infiniti QX56
I have pathfinder 2006,my tire sensor blinking on panel but my tire pressure is good
you will need to go to a tire or any shop to have the sensors reset or check may be a bad calibration or wrong reading will keeep the liligth on
Oct 21, 2010 | 2006 Toyota Solara
2006 chrysler 300 tire senor light, how do you reset?
If it is blinking, it means there is a failure somewhere with the tire pressure system. If it is on steady, it should go off when you inflate the tires to the specified pressure. Make sure you use a reliable pressure gauge, because these sensors can be a bit stubborn. Look in the lower inside of the driver door jamb or on the door itself for the correct pressure. If this does not work, you may have a faulty tire pressure sensor.
It's best to use an accurate gauge and inflate all the tires exactly to the pressure specified on the sticker in the driver door opening. Do this with the vehicle off, then wait a minute before turning the ignition on. This will give the system a chance to reset and update the sensor readings.
Hope this helps!
Sep 29, 2010 | 2006 Chrysler 300
Reset the Tire Pressure Warning light.
well it depends, if you have just reset the tire pressures, the light should go off by itself, if it doesn't then you have a bad tire pressure sensor. If you have replaced the sensor, it must be programmed into the WCM by the dealership.
Nov 21, 2009 | Dodge Durango Cars & Trucks
I have recently change tires on a Mitsubishi Montero 2006, After changing the tire, the tire pressure signal turned on. We defaltedd the tires, check everithing else an the problem still persists.
Bad or dirty valve stem pressure sensor. You can reset the sensor by disconnecting Battery and then wait 90 secs and reconnect. that will set computer to reset. If the valve sensor still may be dirty or gone bad. in that case the sensor will need to be replaced.
Oct 14, 2009 | 2006 Mitsubishi Montero
2006 lexus gs300 tire pressure reset button where is it located?
there is not a reset for the tire pressure monitor system, the system resets its self when all tires are inflated to the proper psi. 35 psi . dont forget about the spare. if all tires are properly inflated check the "2nd set" switch. it is located under the dash on the passenger side. sometimes they get bumped accidently. unless you have a 2nd set of wheels with sensors the switch should be set to "main"
Oct 13, 2009 | 2006 Lexus Gs 300
2006 toyota sienna
I have Toyota with TPMS so I have some experience... things that come to mind off-hand are:
- Low tire pressure
- Pressure sensor damaged during replacement of tires
Check the pressure on the tires.... if the pressure is good,then likely one or more of the pressure sensors were damaged by the shop who installed the tires, have them diagnose and replace it/them (at their expense!). Good luck.
Dec 14, 2008 | 2006 Toyota Sienna
Red Set button underneath the steering wheel
I believe this is for your tire pressure sensors. If the tire pressure in one of your tires drops it will alert you with a light on your dash. When tire pressure is restored, press this button to reset the sensor.
Aug 16, 2008 | 2006 Toyota Tacoma
YouTube Videos Logo
26 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
