Question about Brother LS 2160 Sewing Machine
I am having issues with threading my machine. I have followed the instructions but every time I sew on the machine the thread on the top sews correctly but underneath the cotton gathers up. What am I doing wrong?
    Scholar:
  • 171 Answers
If the thread is bunching under the material it is the top tension. While threading the machine be sure the foot is in the up position until you are done threading it. If you have tried that and it still bunches you need to tighten the tension a bit at a time until it starts sewing correctly. Be sure you are starting with a clean machine and that the thread is not too large for the needle ....
hope this helps.
Posted on Nov 25, 2013
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 97 Answers
SOURCE: thread gathering
I just posted this elsewhere, but it seems relevant to your question as well:
You need to increase your top tension.
Immediately after threading the machine, but before you thread the needle, with the presser foot in the up position, grab the thread at the bottom and top, and "floss" it a few times. This will ensure that the thread works its way into the tension assemblies.
Then raise your tension to about 4.5, drop the presser foot, and you should be good to go.
-R
Posted on Aug 27, 2008
SOURCE: Very inexperienced sewer! How do I thread it?
The way I solved this problem was to take a break! When I resumed I was more patient and found that I wasn't doing the bobbin right. I took my time and got it right this time....hooray!
Posted on Aug 25, 2009
SOURCE: Sewing machine bobbin thread issues
i dont found the bobine
Posted on Nov 22, 2009
  • 255 Answers
SOURCE: sewing machine tension?
Hi! This might be a tension issue, but it also could be caused by the needle. For stretchy fabric you need to use a stretch needle or at the least, a ballpoint needle. (see my tip about which needle to use).
Let me know if this solves the problem, ok?
Happy Sewing!
Robbie
Posted on Mar 05, 2010
Testimonial: "yes it was a combination of the two, thanks!"
How do I thread my white mode 742 also bobin thread is not picking up
Sewing Machine 101 The White 764
White sewing machine model 742 sewing discussion topic PatternReview com
Instruction Manual White 742
Even though the following is not your particular model, the process is very similar from one machine to another, so what you aren't able to get from the above links, you may get from these. Be sure to ALWAYS RAISE the presser foot when threading the top thread so the thread will seat properly.
White Sewing Machine 639 How To Upper Thread The Machine Vintage Metal
White Sewing Machine 639 How To Wind Bobbin Front Loading Bobbin Vintage
Nov 18, 2017 | Sewing Machines
I have a janome 8200, when sewing the top stitch is perfect but top thread bunch under neath and no bobbin thread appears to be used, I have changed threads, bobbins and needle,
Be sure to use a brand new needle.
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread the upper thread. This allows the tension disk to release so the thread will seat properly. Verify that the thread path is correct.
Check that the bobbin is installed correctly (turning the proper direction in the bobbin case) and the bobbin case tension is threaded correctly.
Set the upper tension to the midway point. (This is the beginning point and may need tweaking later.)
Pull the bobbin thread to the top of the sewing project.
How and Why to Bring up the Bobbin Thread P.S.--this works with regular sewing, not just for quilting.
Lower the presser foot and test your machine. Begin sewing slowly.
If there are still issues--upper thread looping, try tightening but if it doesn't improve, the tension mechanism may not be working properly. Check and remove any thread pieces or gunk stuck in the tension mechanism. If still not working, it probably needs service.
If the bobbin thread is still not connecting with the upper thread, the sewing machine's timing is most likely off. (Search the internet for "sewing machine timing." There are multiple web sites and videos available that discuss this OR take it for service.)
Oct 08, 2016 | Janome 8080 Computerized Sewing Machine
Sewing machine isn't sewing at all...got this 2 months ago, used it 4 times, began breaking thread..ready to sell.
Breaking thread could be caused by a couple of things:
1) top tension too tight
2) machine not threaded correctly
3) poor quality thread (don't use bargain thread)
4) needle not compatible with thread/fabric
5) needle installed incorrectly
First thing to try is remove all the thread from the machine, RAISE the presser foot so the thread will seat properly in the tension disk, then re-thread from the beginning--make sure you do not miss any steps.
Usually the factory standard tension setting is with the dial set at the mid-way point between the low and high number. The tension is correct when both the upper thread and the bobbin thread meet in the middle of the fabric.
As a reminder, since your machine is a mechanical, be sure that you are cleaning and oiling on a regular basis. Use ONLY fresh good quality sewing machine oil (not 3-in-1, WD-40, cooking oil, or the old oil from grandma's sewing basket). Follow the instructions in the manual. If you want to do a thorough job, open the top and free arm cover. Slowly hand rotate the handwheel and apply 1-2 drops of oil every place that metal rubs on metal. Do NOT oil rubber, plastic parts or belts. Be sure to apply a drop on the shuttle race every time you begin a new project. Oiling according to the instruction manual should be done every 40 hours of sewing time. If in storage, oil every six months.
Here's a web site that may be helpful:
Sewing Machine Problem 1 Thread Breakage
Here's a manual for your machine:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwjNgO6QxsDJAhXnjIMKHXzFABoQFggtMAI&url=http%3A%2F%2Fecx.images-amazon.com%2Fimages%2FI%2FB1dzfyluFLS.pdf&usg=AFQjCNEBTgKmXv2EyHiiw-px33CFogPHXA&cad=rja
Here's information about needles:
http://www.schmetzneedles.com/all-about-needles/
Dec 03, 2015 | Brother LS-2125 Mechanical Sewing Machine
Thread keeps breaking when I sew.
one of three issues: top tension too tight, bottom tension too tight, needle timing off.
Oct 21, 2015 | Elna 2005 Mechanical Sewing Machine
Help! I'm having problems with my Necchi Lydia 3. Firstly when threading up, the threaded needle refuses to draw up the bobbin thread. I've followed the instructions and the needle comes in and out but...
try a different bobbin
make sure the bobbin in turned the right way in the bobbin case
also the machine may have a timing problem, and having it checked to would be a good idea.
Sep 07, 2013 | Necchi 4575 Mechanical Sewing Machine
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
The take up thread lever will not come out far enough for me to thread sewing machine
that is because the thread lever on these machines does not come out, you have to place the thread over the top of the arm and it will find the ****.
then continue to thread your needle.
there is no hole to thread it is very easy when you have done it once, just follow the instructions in the manual carefully.
Mar 05, 2011 | Brother XL-2230 Mechanical Sewing Machine
Brother LS 2160 Sewing Machine Logo
114 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
