Question about Microwave Ovens
How to use eletrolux mirowave oven EM20GSLN-MMZ About temperture; baking;combination
What is convection cookong
A convection microwave is a combination of a standard microwave oven and a convection oven. It allows food cooked in the convection microwave to be cooked quickly, yet come out browned or crisped as in a convection oven. However, most cakes cannot be baked in a microwave oven - only those without an open grain structure, such as brownies. There are microwaves which contain electric browning baking elements. A true convection microwave has a high velocity forced air fan to circulate the hot air uniformly.
more about Convection microwave
May 28, 2016 | Microwave Ovens
After I replaced the lower coil in my Frigidaire oven, the self cleaning part does not work.
Hi Carol Eggers, thank you for your inquiry!
I understand that your wall oven is not allowing you to perform self-clean after you replaced your bake element. It sounds like it could be an issue within the control panel or sensor inside of your oven. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 22, 2014 | Frigidaire FPMC2785KF Professional 27...
GE JVM1790WK convection microwave
I assume you've referred to your owner's manual to be sure you are operating the convection properly?
If for some reason you don't still have your owner's manual, you can get it here. See the tips on page page 30.
You can also do a hard reset by unplugging the oven for a couple of minutes, plugging it back in, then setting the clock and trying again.
If it's still not working, you may have a bad sensor or other problem.
Sep 04, 2012 | GE JE1590 Convection / Microwave Oven
E305075FPSA HighSpeed Eletrolux the door appears to not be closing tight.
No! this not normal, I'am concerned about microwave leakage, and a 1/8 gap is to much, should be tight against the seal "major safety factor" the door is out of alignment or the bottom latch is not secure "to much play" I recommend a pro simply because he needs test for leakage when the door is properly fixed.
Mar 22, 2012 | Electrolux ICON Microwave Combination Oven
I have a Frigidaire Electric smooth top range and oven. when I set turn on the burners they do not light up or get hot. When I try to bake I press the Bake button and set the temperture but the oven never...
HI.CONTROLS MIGHT HAVE BEEN LOOSE.oR LOOSE CONNECTION BETWEEN the control.Check the control connection inside .It might respond but connection has been loose.hope this helps..
Jun 21, 2011 | Frigidaire Microwave Ovens
Cooking temp to bake cake inn convection mode samsung model
Hi I guess you are cooking usng the combination setting? if so The cake will be hard due to increased microwave energy, I would suggest reducing the microwave energy on the Samsung unit when using the combination setting.
Hope this helps
Jan 07, 2010 | KitchenAid KHMC107BT Convection/Microwave...
The Mirowave, Convection Cookbook, Page 112 states "This recipe is apppropiate for the two shelf convection baking feature.Refer to Use and Care Guide." My PFB 1590DMBB GE Profilet Ceovection...
The use and care guide is what GE calls their owner's manual, but you can download GE owner's manuals and installation instructions here.
Sep 05, 2008 | GE Microwave Ovens
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
