Question about Faber MIRR36BK Image 36" Mirror Wall Mount Hood 600 CFM
I can not regulate the power anymore it only blow at the strongest level all the time and somethimes it wont start at all
    Problem Solver:
  • 12 Answers
You should have a service person come look at the hood, either the motor, capacitor or control board. Visit http://faberonline.com/service.html to find the servicer in your area, thank you
Posted on Jan 30, 2014
Nissan 2007 xterra won't start, reading code U1000 and P0462
Hi,the code p0469 is....fuel level sensor circuit low input,
and code u1000 is....scp (11850) invalid or missing data for primary ID.
Im sorry I cant tell you what thay mean,but I hope this was some help to sorting the problem all the best.
Oct 17, 2016 | Nissan Cars & Trucks
Why would the power steering pump blow the cap off on a brand new pump I had installed to stop whining ?
Either too much fluid was refilled into the pump or one of the valves in the power steering rack has failed and is pressurising the pump chamber causing the cap to blow off. When you replaced the pump , there would still be a lot of fluid in the rack and all the connecting hoses. If you refilled the pump to its full level, when the pump is started, there will be too much fluid in it causing the same problem. Take some fluid out , down to its lowest level, with the car idling and getting someone to slowly turn the steering wheel back and forth, recheck the level and top up if required to its full mark.
Apr 19, 2015 | Cars & Trucks
I just put a brand new battey in my 95 katana but it still.loses power and dies and wont start
Sounds like your regulator/rectifier has failed. This is a fairly common fault on GS and GSX models, particularly the smaller capacity (below 750cc) models. Did the oil level fall below minimum at any time, because this can cause the generator on some models to overheat, causing a power surge which can burn out the regulator. Get the generator checked and fit a new regulator/rectifier.
Oct 10, 2012 | Suzuki GSX 600 F (Katana Motorcycles
My haier tv model no. hl42e wont come on
Hello
If its power indicator LED at the front panel is also do not light up, there is some fault with its power regulator board inside it. Open your tV, and locate the power regulator board. It is easy to locate as, AC power goes direct to it after ON/OFF switch. Check the protector fuse [a glass cartridge type will be used] is burned out or not. If it ahs burned out, replace it with same type in both size and ampere capacity. You can not is rating on its rims; or it will be markde on the printed circuit board itself, under the fuse holder.
If the newly inserted fuse also blow out as soon as you switch ON the Tv, never use anymore fuses, as there is some direct short circuit with that power regulator board. It is better to replace that boad as card basis, than making any "surgery" to it. OK.
Oct 11, 2011 | Haier HL42E LCD TV
Hello there, every function works, except
Timer "hangs up" at the start or lid switch is defective.
Jul 03, 2017 | Fisher and Paykel WL37T26D Top Load Washer
2005 Kia Optima auto trans problem
I had the same problem... just got my car services and took car to transmission spec. they told me that its the pump inside the tranny thats broken or something. while the pump is working >ie under acceleration it blows fluid out the seal (which seal im unsure) once the fluid level drops below the seal level it wont blow as much fluid out. if you check the levels you should notice that the fluid is well under level. Major job because you need to remove the transmission to get to the problem If that isnt the problem another issue could be a seal on the left or right driveshaft.This isnt as major as the other because you wont need to remove the transmission but time is required to remove the driveshafts to replace the seals. The first problem cost me about $600AU
Sep 18, 2008 | 2004 Kia Optima
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
In focus 70+ light flickers
I have the exact same problem, it comes and goes, but i noticed that the screen was flickering more when the projector was tilted up a bit.
I shifted the cable from s-vhs to vga and now i dont have this problem so often anymore.
I also have the common problem that it sometimes wont start up when i power it on, or it shut down after a few seconds. It seems to be a loose wire somewhere, but i just give it a punch and then it starts..
Aug 06, 2008 | InFocus LP70+ Multimedia Projector
Faber MIRR36BK Image 36" Mirror Wall Mount Hood 600 CFM Logo
109 people viewed this question
Top Faber Kitchen Ranges Experts
Steve
Bill Boyd
dik stukkien
dik stukkien
Are you a Faber Kitchen Range Expert? Answer questions, earn points and help others
