Question about Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD SCREEN 154 WXGA MATTE CCFL (654367710876)
Xp is not getting installed because it cannot search storage place at the time of installation
When i try to install a fresh windows xp ,it loads all files after that it ask to press enter for install of new xp after it shows cannot find storage device
    Scholar:
  • 171 Answers
Sounds like your hard drive needs to be replaced. If you have been in the computer lately, check to be sure the hard drive wasn't disconnected by mistake. If it is then you may have a bad drive. Why were you replacing the operating system (XP) for PC problems of this nature you will need to provide the circumstances leading up to this point. Probably best to find someone who can look at it in person.
Posted on Nov 25, 2013
My ksuser dll for windows xp profesional
Just boot from the xp professional cd and run the recovery console.
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
Apr 19, 2011 | Microsoft Windows XP Professional
Haha! I deleted folders inside the Local Disk C:\Program files then after that the computer would always ask to restart it, every time I try starting it. Huhu Help, and these folders are not inside the...
or
  • If this solution helped Never go to drive C: again. Vote for this solution and rate it
Apr 18, 2011 | Computers & Internet
I am cannot install OS Xp on laptop blue Il1,because drivers not support
Actually the problem is that the sata raid drivers of the IL1 is not readily available on the windows XP installer package. Another problem is that you cannot use the drivers on the installation because it uses a disk drive for loading and the IL1 have no disk drive or CDROM with it.
The solution is download or get the sata raid driver for the IL1 placed it on a diskette and attached an external CDROM and an external disk drive on your IL1. Open your notebook place the Windows XP CD in the CDROM, place the sata raid driver diskette on the disk drive. Make sure that the booting priority is set to the usb CDROM.
Upon loading of the Windows XP installation, you will notice a message on the status bar below the screen asking you to press F6 if you want to add additional device, press F6 and follow the instruction on adding the sata raid driver. Then your installation will continue till it finishes the Windows XP installation.
There is another way, but a little complicated. It is making a flashdrive installer of Windows XP OS. an integrating the sata raid driver in the flashdrive Windows XP OS installer. there's a guide somewhere in the internet that discuss the process step by step, I just can't remember on what site. I fount it by searching the net, I'm sure you can find it if you have time.
For now that's all I can share. Good luck friend.
Dec 14, 2010 | CTL IL1 Notebook
Had to load window xp on computer than try loading installation driver cd . it came up with error
1) Are you trying to install using Recovery CD and getting that error try installing Xp directly.
2) If you want to install Fresh windows, Boot pc with windows Xp and follow the instructions. And do full format your drive once where you want to install your XP, and continue installation..
Sep 18, 2010 | ATI RADEON 9550 Graphic Card
I put 2 disks in raid 0 array on this controller
When you say "after merging the driver via a floppy at the txt setup" I think you are referring to pressing the F6 key to load the raid drivers. But I don't understand "restarting setup".
You will need the correct XP64bit drivers loaded on a floppy for this to work.
Maybe a good place to start is a temporary install of XP using 32bit drivers to prove all components are working.
Nov 01, 2009 | Adaptec 1220SA (2232100-R) Storage...
Laptop powers on, but windows doesnt load
Boot PC from Windows XP installation CD you will be ask to instal fresh copy or repair existing installation - go for "fresh copy" software will analyze you PC and try to find your previous copy of Win XP you will be ask again to repair copy of your existing Windows Xp now go for "Repair" option so installation software restore all Windows files and will keep all your settings*.
This solution is only temporary because IE 7 and 8 will no longer work after restoring - backup all your data and instal fresh copy of Win XP after all and always keep Your Backup up to date!!
Sep 07, 2009 | Medion (40010998)
Sir, Iam using toshiba Satellite L45-S7423 model laptop.already this laptop contain windows vista. i want to instal Windows XP.can you please help me how can i install Windows XP and how can i download...
I RUN BOTH XP AND VISTA ON THE SAME SYSTEM YOU ARE BEST TO PARTITION THE DRIVE AND PUT THEM IN SEPERATE SECTIONS, I USE XP FOR KIDS OLDER LEARNING PROGRAMS WITH 256 RESOLUTION AND UPTODATE PC ON VISTA SIDE. AFTER FDISK FORMATING DRIVE I FIRST INSTALLED XP IN PARTITION THEN UPGRADED WITH FRESH INSTALL OF VISTA TO SEPERATE DRIVE , WHEN BOOTS ASKS YOU WHICH START UP SYSTEM YOU NEED N U LOAD DRIVERS IN NORMAL WAY AND GET DRIVERS OFF INTERNET , U CAN USE VISTA SETUP TO GET DRIVERS PUT ON DONGLE THEN RELOAD ON XP AND LOAD DRIVERS.
YOU WILL HAVE TO ADD A PARTITION TO YOUR DRIVE IF GOT SPACE AND DONT WANT TO START FRESH.
THEN SEE IF XP CAN BE LOADED ONTO IT ILL TRY IT ON MY SYSTEM TO C IF LET U GO BACKWARDS RATHER THAN UPDATING
ACTIONMAN
Feb 27, 2009 | Microsoft Windows XP Professional With...
Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD SCREEN 154 WXGA MATTE CCFL (654367710876) Logo
47 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
