How to setup iRC2380i on network and printer?
Removing the optical part with canon irc2380i
Dear Sir,
Please clean the cleaning blade and try printing a test page if that does not fix the problem then please try to replace the 'Laser beam scanning unit' But before replacing please try to clean the unit with soft cloth.Hope this would help
kind regards
Sep 07, 2015 | Canon iRC2380i
Factory reset canon irc2380
Hi Anonymous, The link below is a youtube video showing how to set default settings, I hope this helps.........CHEERS..
Setting Default Copy Settings on Canon IRC2380
Dec 06, 2013 | Canon iRC2380i
Where is the IP address located on my Lexmark s515 printer
Printing a network setup page
A network setup page lists the configuration settings of the printer, including the IP address and MAC address of the printer.
  1. Load plain paper.
  2. From the printer control panel, navigate to: button_home_0.jpg > Setup > button_select_0.jpg > Network Setup > button_select_0.jpg > Print Network Setup Page > button_select_0.jpg
Nov 30, 2013 | Lexmark Office Equipment & Supplies
Canon irc2380i have error e000003-0001
Hi
This is a problem with the fixing heater part, Replacement of the fixing heater inside the the main heater unit will need replacing.
Aug 21, 2013 | Canon Office Equipment & Supplies
I need you to send me the user guide for Canon iRC2380i on this email address
I have got two email addresses for the same user registered in canon IRC2380i AND I need just to remove one which has an email mistake. Tks
Nov 22, 2012 | Canon iRC2380i
Irc2380i printer driver
HI..
meeranarsaia.. TRY THIS LINK, HOPE CAN SOLVE YOUR PROBLEMShttp://driverscollection.com/?H=iRC2380i&By=Canon
Mar 30, 2012 | Canon Office Equipment & Supplies
I think I accidently cleared my wireless wifi on my printer.... the wifi light is orange instead of green so not connecting
Try to print the network settings page to determine if your printer is still connected to your wireless network or not. On the printer operator panel, press the Setup button -> Network Setup -> Print Setup Page. Check the SSID if the printer is still registered to your wireless network. If not, you may need to reset your printer's wireless network adapter. Press Setup -> Network Setup -> Reset Network Adapter. The wifi light on your printer will then momentarily turn off. Once it turns on solid orange again, you may reconfigure your printer to connect to your wireless network.
If your printer is still registered to your wireless network, then it could be just a slight communication problem. Try to unplug and replug your printer into the power outlet to reset it. Doing this usually fixes minor communication issues.
May 03, 2011 | Lexmark X4690 Wireless InkJet Printer
Canon irc2380i erorr e0000670102
i am sure that this is a problem with the drum, it has reached the end of its life. you have to replace it to fox problem
Jul 20, 2010 | Canon Office Equipment & Supplies
Cannot get Win 7 driver for iRC2380i
There is no Windows 7 driver for this machine. All the latest drivers are available from Canon Support at the following link
http://software.canon-europe.com/products/0010555.asp
Select your Operating System and Language.
The official line from Canon on Windows 7 drivers is to use the Vista Drivers until the Windows 7 drivers are released at some point in the future. Note that Windows 7 drivers will not be released for all machines.
Nov 06, 2009 | Canon Office Equipment & Supplies
115 people viewed this question
jasbo
jasbo
