Question about Tablets & eReaders
How to connect tablet to tv - Tablets & eReaders
Connecting tablet to tv
Use a usb to usb cable. Find an application fron application stote to send tablet screen picturr to tv. Install it. Run it
In case that you have a ei fi tv. Then srsrch for those application that broacast screen to tv. Air connected, stream tv mirroring, play to tv, etc.
Sep 19, 2016 | Tablets & eReaders
Connect my samsung galaxy S Tab 2 to my Proscan TV 32LB45Q
It should be pretty much straight forward.
Can you check by setting both tablet and TV to 720p or 1080i?
I am not sure both can support 1080p
How to Connect Tablet to TV using HDMI Easy Fun
2 WAYS TO CONNECT PHONES TABLETS TO TV wire vs wireless review
Jun 05, 2016 | Samsung Tablets & eReaders
Can i connect my tablet to the tv
Are you attempting to screen mirror, display your photo's / video's? What make of tablet and what make of TV is it please?
Are both your tablet and TV connected to your router?
Apr 15, 2016 | Tablets & eReaders
Rca 10" tablet need to connect to my phillips tv.Plug up nothing happens,Took a hdmi/rca cable from camera, hooked tablet to tv that made my tablets screen go black until unpluged from the tablet.
Screen going black usually means it is connected to another screen. Is there a setting on the tablet to enable output settings and a setting on the TV to enable input settings.
Jul 19, 2015 | Tablets & eReaders
How do I connect tablet to tv
select on tv menu the hdmi source and the game is done
Mar 10, 2015 | Samsung Tab Tablets & eReaders
How can i connect my tablet
Just going to go through steps.
1. mIni hdmi to to tablet
2. hdmi on other end of cable to a hdmi input on tv.
3. go to input on tv and change input where you plugged in hdmi.
4. start your tablet. what ever is on your tablet will now show up on tv. (home screen, movies, e-mail, etc.)
Just a reminder, you have to switch input on tv each time.
GOOD LUCK
Apr 19, 2014 | Acer Iconia A1-810-L888 7.9 inch MediaTek...
TF700 WON'T TURN ON
There are a couple things to try.
Possible Problem: The tablet may have gone to sleep and a newly installed app or update is preventing the tablet from coming out of hibernation.
Solution: The tablet likely needs to re-start.
The trick is to know whether your tablet is in hibernation (actually running but not screen is turned off) or if it is actually turned off.
Scenario 1, tablet is on but is in hibernation mode
1. Press and hold the power button until you feel the vibrate. Then release. Wait 3 minutes (to make sure the tablet shuts down). After the 3 minutes go to scenario 2
Scenario 2, tablet is turned off.
1. Press and hold the power button. Keep pressing even after you feel the vibration (for about 30 seconds).
Other possible solutions:
If that does not work, then ...
2. Disconnect the tablet from the keyboard and press and hold (same as step 1 scenario 2).
3. If the others methods do not work, connect the tablet to a PC (with internet connection). Leave the tablet connected for a minimum of 30 minutes, but upto 2 hours. With the tablet connected to the PC, press and hold the power button (same as step 1 scenario 2).
If none of those worked, connect the tablet to a TV or monitor using the HDMI connection. If the TV/monitor displays the tablet, then use the display on the TV to reset to factory defaults and force a re-boot. While it is shutting down, disconnect from the TV.
If that does not work, check the user manual for how to reset the tablet to factory default settings.
Last but not least, contact Asus support because you might have to send it for service. But I suspect scenario 1 will work for you.
Feb 12, 2014 | ASUS Transformers Pad Infinity TF700TWIFI...
Buy a compatible HD cable. Depending on your device this may vary. If you have a Samsung tablet, it will connect to your TV if your TV is also a Samsung Smart TV.
Nov 27, 2013 | Tablets & eReaders
How do i connect my tablet to the tv
Visit my blog lol
http://pcgadgetdeni.blogspot.com/2013/02/how-to-watch-videos-from-your.html
Feb 26, 2013 | Lenovo Tablets & eReaders
Tablets & eReaders Logo
14 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
