Question about Saws
How do I change the blade?
How do I change a blade on a Skilsaw 5275. There doesn't appear to be a brake to stop the bolt assembly from rotating while trying to remove the bolt.
Use a hard board to hold blade tight
rem: unplug power cord... thats how i've had to do it
at times
Posted on May 08, 2009
I Have A 2.5hp skilsaw classic model # 5275 ball bearing output and the bolt wont lossen what do i do?
put a wrench on it and give it a rap with a hammer. oil the bolt, reinstall it
Feb 13, 2018 | Cars & Trucks
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
Have a Skilsaw 3315 that works fine. Except the blade continues to spin after shut off. It’s not a loose blade. I’m not sure what else to fix. Seems like a brake doesn’t engage or something. Please help.
kninejk Feb 11, 2018
Based on your model number given this saw does not have a blade brake so the blade will spin after turning the saw off, it must coast to a stop.
Feb 11, 2018 | Garden
How to change blade on skilsaw 5380
on a circular saw
pull the power lead from the plug
using a screw driver , place the blade between the teeth and turn until the screw driver is jammed under the plate
use a ring spanner and undo the nut that holds the blade on
pull the blade out and fit the new blade with the direction arrow in the right direction
replace the plate and the bolt do the bolt up tight
rotation will tighten it up
some blades have a hole in the blade in which to insert the screw driver to hold the blade , or a lock lever behind the cover to hold the armature shaft while changing the blade
Dec 21, 2016 | Saws
Where is the blade lock on the skilsaw 5155
Hi Emory:
Your question made me think................
None of the skil saws that I have owned, or still have, came with a blade lock. Maybe yours has one, but if I needed to pin the blade while undoing the bolt, I'd do like I always did......... Unplug the saw....... and slip a carpenters pencil between the teeth and rotate the blade until the pencil came up against the deck.
There is also usually a hole in the blade, and a nail slipped through the hole makes a perfect blade lock.
Oct 03, 2015 | Saws
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
How to remove arbor bolt to change blade
Best thing to do is to just rest the blade teeth against a peice of scrap wood, and use the allen key/spanner to undo the bolt. As the bolt undoes in the direction of the cut, the blade teeth should dig in and stop it turning. If the blade lock isn't working anymore, it could mean that it has broken inside, so be careful, incase there is a bit of loose metal in the gearbox, it will be quite catastrophic if it gets caught in the gears.
Jul 18, 2014 | Bosch 7 - 1/4" Skilsaw Circular Saw
My Skil Worm Drive Skilsaw Blade stops when cutting
If the blade stops it could be from a loose hex bolt, flanges missing or you have a gear problem. UNPLUG tool and check the blade first. I would remove the fill screw on the gearcase and see if the oil has metal shavings in it, if it does the gears are worn allowing the blade to slip. If not I would recheck the blade. Did this suddenly happen and if so what did you do prior to your problem
Mar 12, 2012 | Saws
How do I replace a skilsaw blade?
The saw has a bolt in the center of the blade. The saw blade will have to be held in place, (so it can't turn), while the bolt is being loosened. Pay attention to the rotation direction, as your replacement will need to rotate in the same direction. Once you have removed the bolt, there is a centering spacer that fits between the bolt and the blade, remove it paying attention to how it fits..you will need to put it on the new blade in the same manner. You can now remove your blade and replace. Good Luck. I hope this is very helpful!
Nov 14, 2009 | Craftsman Saws
Saws Logo
1,163 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
