Question about Dell OptiPlex 760 MT Desktop Computer
No signal on monitor
Showing no signal to the monitor ..any suggestions please
    Problem Solver:
  • 5 Answers
Sounds like a bad video card or bad monitor. Check the connection to and from the monitor to the pc. If the monitor power light turns on, Then I would suspect the problem to be the video card.
Posted on Nov 25, 2013
Out of nowhere my monitor is showing Check Signal Cable and the digital analog box is showing as well - why?
It is possibly a loose VGA or DVI-D connector on the monitor internally. Those are the outputs to provide you video. I would suggest replacing cables, or too buy a new monitor.
Feb 21, 2016 | Samsung 216BW Refurbished
Replaced power supply and the monitor shows no signal and goes to sleep mode. Checked all connections, tried another monitor, any other suggestions?
Hi!
It seems like the problem is within the computer, rather than the monitor itself...
Please follow my tips to resolve your problem.
Regards,
Pelu.
May 24, 2011 | Compaq CV 735 (White) 17 in.CRT...
Monitor showing no signal and button not working
The monitor needs a signal ( source), i.e., DVD, TV, to show a picture. If your monitor shows no signal then either the source is not connected or not functioning. Check the connections from the monitor to the source. Also, check that the source is functioning properly and is receiving power.
May 24, 2011 | Sony XVM-H65 6.5 in. Car Monitor
We are using a Dell 2300 projector. The Power
check that you have a signal going out of the monitor socket on your lalptop.
On Dell with projector connected and switched on, press the blue fn button bottom left usually, and while holding, press one marked CRT/LCD, (maybe f8) this will cycle to the following.
laptop only, laptop and monitor, monitor only, while holding Fn button press until you have desired outcome.
hope this helps.
Apr 12, 2010 | Dell 2300MP Multimedia Projector
Monitor shows "no signal" and will not start to windows. I've tried unplugging and replugging it. I've switched dvi and vga cables. The monitor turns on, but keeps on displaying "no signal" and then shuts...
the problum is with the PC, test monitor with a good pc,,
Unplugig all cards and ram chips and re try if it works then puging them back in ..Sounds like the pc has a bad ram chip or card some times they just get bad connection,
Mar 30, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
Monitor shows on receiving signal, will not display image.
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or no picture is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 02, 2009 | ViewSonic VX2235WM Monitor
Montor shows a blank white screen and is unresponsive
Please try to connect the monitor to another PC, if it continues to happen, then probably an internal electronic part/s of your monitor is cold soldered / defective which failed to send signal to other hardware parts of your monitor thus you only see white display. I suggest to bring the unit to an authorized service center fix / replace the cold soldered / defective part/s. regards
May 28, 2009 | Dell Computers & Internet
Lcd GEM Gl-822A--dont show image
It sounds like a problem on the video / signal circuit board inside needs to have electronic troubleshooting.
Jan 21, 2007 | 3G Technology GEM GL-822A/B 17" Flat Panel...
Dell OptiPlex 760 MT Desktop Computer   Logo
96 people viewed this question
Alun Cox
