My tv is such on the stop wizard when I put the input on tv and I can't find the original remote
SOURCE: Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
SOURCE: Setting up a Harmony 659 universal remote without original remote
Hi. Chances are the commands for your TV are already in the Harmony database. All you would need to do is add the TV to your remote and it should work.
1. In the software, click 'Add Device.'
2. Enter in the model number, etc.
3. Update the remote
Testimonial: "Thanks for the quick response, It's working!"
SOURCE: re: a total reset without a remote control
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments. Pull up older posts. You can get all details. Site is listed with Google. You can locate it either at the bottom part of first search page, or at the top of second page. Sometimes, one among the advertisements by the side and bottom of each post might help you to get details about the availability of spare parts and other components.
SOURCE: need original remote control for Westinghouse TV Model LTV-17v1 SL
If you want to buy its original remote control, contact the authorized service center for Westinghouse at your town.
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
