Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Hello, I have a craftsman dyt 4000 with the Briggs 18.5hp and auto transmission. I turned it off after running for about an hour and when I tried to crank it back up it flooded. I waited a while and it started up but ran poorly. I parked it about a week ago and when I went out to crank it today it turned over but blew the little hose off behind the carb and shot gas everywhere, I put the hose back on and tried again. The same thing happened so I pulled the air filter and it was soaked with gas. I looked in the carb and its full of gas. I have no Idea what to check first. Its almost like the fuel is running to the carb constantly with way to much pressure. Do you have any idea of some things to check?
  • Corey Malone
    Corey Malone May 08, 2009
    Thanks for the suggestion Chris I typed that up last night before taking things apart but I had planned to check stuff like that and report back my findings........Ok I have taken the carb off to try and ***** the situation. I have found that gas is in everything, The manifold vent hose had gas coming out of it and the cylinder behind where the carb attaches was full. I took the spark plug out and gas poured out. I also think the oil is full of gas as well. This motor is a ohv intek series. I dont think I siad that above. It has wires going to the bottom bowl of the carb so I assume its an electric float. I think I should start with a rebuild kit on the carb and draining everything, I wanted to see if anyone else had anymore suggestions of thinkgs to check. Im only guessing at this point its the carb or float. The bowl on the carb has no bolts so Im trying to figure out how to get it apart. Thanks in advance for any help.
  • Corey Malone
    Come to think of it couldn't this all be cause if the spark plug stoped getting voltage and my wife kept turning it over too long before she got me?
    Sergeant:
  • 201 Answers
Remove fuel bowl and check needle valve and float assembly
Posted on May 08, 2009
Why is my Craftsman dyt 4000 transmission slow in reverse?
change hydro fuid and filter see if that does it
Aug 27, 2014 | Garden
How do you remove an engine from a Craftsman dyt 4000 lawn tractor?
remove the deck and drive belt, then the pully and the four mounting bolts. unplugg all the wires and lift the motor out.
rural king has briggs and straton motors at their stores for a cheaper price than on line. I got a 18.5 hp for $420.
Jun 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
Sep 29, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
What engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
The only thing you have to do is have the size (diameter) and lenght (from cranckcase to end of shaft) of the shaft you have on your b&s and just go to your local Honda dealer , give them your shaft size and they should be able to give you all the options for a brand new motor . I really believe you can get a Honda 20hp model GXV620 or a 24hp model GXV670 that will replace your B & S motor .
Hope this help .
Sep 01, 2009 | Garden
Craftsman DYT 4000, 24 hp 48" deck. While I was mowing, the blades stopped turning, started again, and then stopped. I shut down, all looked OK, tried to start and nothing. No click, nothing. Any ideas?
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Jun 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
686 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
