Question about HP 4250 Monochrome LaserJet Printer
HP C3180 envelope jam
I am trying to print on A7 (7-1/4" x 5-1/4") envelopes but the printer jams every time.  I think it might have something to do with the thickness of the envelope, but 3 printed out just fine before the jamming started.  Any ideas? Thanks.
  • 2072 Answers
SOURCE: Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Posted on Feb 19, 2008
  • 3 Answers
SOURCE: HP C6180 photosmart all in one printer jam
Thank you for coming back. I decided to return the printer to the retailer as it is just inside the warrany period.
Rgds
Posted on Apr 29, 2008
  • 320 Answers
SOURCE: Envelopes keep jamming
hello! try cleaning the paper feed roller where you feed the envelope in with denatured alcahol good luck
Posted on Jan 26, 2009
  • 20 Answers
SOURCE: My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
Posted on Sep 06, 2009
Ranglo
  • 1194 Answers
SOURCE: envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Posted on Feb 20, 2010
13.05.00 jam in
Hello Konnaris Nikos,
Welcome, and thank you for using FixYa!
To answer your question: There are five known causes for the error code you are seeing.
1. Paper did not get to the fuser within the expected time.2. You are printing on smaller media which is likely encounter 13.05 jams - especially if using media with lengths from 160 to 170 mm (6.25 to 6.75 inches).3. A worn-out fuser can cause both 13.05.00 and 13.06.00 jams.4. Lightweight media that is acclimated in a high-humidity environment can curl excessively and cause 13.05.00 jams.5. Legal paper used when the job calls for envelope will result in a 13.05.00 or 13.06.00 jam instead of a size error.
You will need to have the printer examined for a maintenance kit to be installed. You may also want to check and make sure your print project isn;t set to use Envelope as the paper media and the drawer is loaded with Legal paper.Thank should fix your issues.
Have a great day!
Dec 01, 2011 | HP LaserJet 4200 Printer
HOW DO I PRINT ENVELOPES ON A BROTHER MFC-465CN PRINTER? SCREEN TELLS ME THERE IS A PAPER JAM WHEN THERE'S ONLY ONE ENVELOPE IN THE TRAY.
my brother mfc 7860 tells me i have a jam when i print envelopes only- there is no jam and will print the next 'page' fine- have to turn it on and off 4-5 times to get it to print one- any ideas anyone???
Aug 11, 2010 | Brother MFC-465CN InkJet Printer
Envelope jam HP Officejet 8500
Steps:-
3) Click Options .
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Not printing envelopes and printer locks up
Use a small flash light and check for any debris blocking the roller from the tray...
Sep 24, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Paper pickup not moving
Have you set the margins?????
If you push the left margin over, it may help.
Jun 08, 2009 | Konica Minolta magicolor 2400 Laser...
Labels are printing in reverse
Whereas I do not have this same printer, the problem may be in the printer settings.  Go to your printer settings/properties and select printing preferences.  Select the "finishing" tab and look for "mirror" and see if the box is checked.  If checked, un-check it. If the mirror box is not checked there is a software glitch.  In this instance go to the "control panel" and select printers.  Delete the printer.  Download the most recent driver for your Operating System and re-install the software.
Try another label/envelope program: Avery has free downloads,  MS Word has a big listing of address printing, as does most word processors.  Check open source software such as open office.  Except for Word, there are a lot of free software out there.
If that does cure the problem, there could be a defect in the printer firmware.  Might need repairing or replacing.
Hope this helps.
May 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp l7580 carriage jam - how to fix it
use the back door for printer and you can remove the envolupe
May 04, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Envelopes jam in my hp 6940; paper sheets feed fine
I have had varying success with envelopes. Can you feed in the other way round? Sometimes different envelopes perform better. The peel N seal can be very difficult
Apr 10, 2009 | HP Deskjet 6940 InkJet Printer
HP 4250 Monochrome LaserJet Printer Logo
223 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
